Author Topic: Lightweight Mesh NWK_ACK  (Read 1162 times)
Offline piotrvvTopic starter
« on: January 13, 2017, 10:04:56 am »
Hello.
  I try to do end device with repetition of transmission and I want to clarifying some information.
I activated:
appNwkDataReq.options = NWK_OPT_ACK_REQUEST | NWK_OPT_ENABLE_SECURITY;
in
void appSendData(void)
Q1. Does NWK_ACK works without enabled NWK_ENABLE_ROUTING?
Q2. Does NWK_ACK works without enabled #define NWK_ENABLE_ROUTE_DISCOVERY?
Q3. Where I should get information about: NWK_NO_ACK_STATUS?
void appDataConf(NWK_DataReq_t *req)
is the right place?
If so...
Q4. When NWK_NO_ACK_STATUS information is available?
After
#define NWK_ACK_WAIT_TIME 1000
time? Or maybe somewhere earlier?
Q5: Which program events call
void appDataConf(NWK_DataReq_t *req)"
Best regards,
piotrvv
Online ataradov
    • Personal site
Re: Lightweight Mesh NWK_ACK
« Reply #1 on: January 13, 2017, 05:34:22 pm »
Yes, it does. But you still will be able to communicate only with devices within the range, obviously. But they should acknowledge the received frames.
Absolutely.
is the right place?
That would be the only  place.
At the moment this function is called. And it will be called after ACK wait time if no ack is received.
It is called only in response to NWK_DataReq(). If there is no pending response, then this is just another function. It has no special meaning, it takes the meaning as a request callback when you specify it as a parameter of the request.
Alex
