Thanks for the reply, I use STM32L152RB chip and CooCox as IDE. Right now i managed to display standard font on the lcd but i wanted to display bigger numbers.
the font data posted above (in this thread) is a bigger size font.
best way to understand how to write these is to look at the extracted data - eg, for the number '5'
0x3F,0x0C,0x7F,0x1C,0x63,0x38,0x63,0x30,0x63,0x30,0x63,0x30,0x63,0x30,0x63,0x30,0xE3,0x38,0xC3,0x1F,0x83,0x0F, // 5
is (ignore the border I added):
| 111111 11 |
| 1111111 111 |
| 11 11 111 |
| 11 11 11 |
| 11 11 11 |
| 11 11 11 |
| 11 11 11 |
| 11 11 11 |
|111 11 111 |
|11 11 11111|
|1 11 1111|
so, to display this correctly, you must write odd bytes out, then re-position to write position and and write the even bytes
the same technique can be used for even bigger fonts
