I've looked at a few examples, but so far not getting it working.
I have it successfully transmitting a 0. I'm trying to get it to receive now.
After reading:
https://electronics.stackexchange.com/questions/266918/stm32f031k6-hal-uart-interrupts-problemThe answer suggests having to call HAL_UART_Receive_IT(&huart1, uint8_t *pData, uint16_t size) which I don't understand. I am familiar with AVR and an interrupt would fire, do what it needs to do, and then you could check variables it changed to see what has happened or retrieve bytes from a ring buffer. Why call this function? Is it blocking?
I don't think it gets called because it always outputs 0's and doesn't change aTxBuffer[0] to a '1'...
I added the void USART5_IRQHandler() function because of the link above, but it did not have any effect....
* File Name : USART.c
* Description : This file provides code for the configuration
* of the USART instances.
* COPYRIGHT(c) 2017 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "usart.h"
#include "gpio.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
UART_HandleTypeDef huart4;
UART_HandleTypeDef huart5;
UART_HandleTypeDef huart7;
/* UART4 init function */
void MX_UART4_Init(void)
huart4.Instance = UART4;
huart4.Init.BaudRate = 115200;
huart4.Init.WordLength = UART_WORDLENGTH_8B;
huart4.Init.StopBits = UART_STOPBITS_1;
huart4.Init.Parity = UART_PARITY_NONE;
huart4.Init.Mode = UART_MODE_TX_RX;
huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart4.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart4) != HAL_OK)
Error_Handler();
/* UART5 init function */
void MX_UART5_Init(void)
huart5.Instance = UART5;
huart5.Init.BaudRate = 115200;
huart5.Init.WordLength = UART_WORDLENGTH_8B;
huart5.Init.StopBits = UART_STOPBITS_1;
huart5.Init.Parity = UART_PARITY_NONE;
huart5.Init.Mode = UART_MODE_TX_RX;
huart5.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart5.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart5) != HAL_OK)
Error_Handler();
/* UART7 init function */
void MX_UART7_Init(void)
huart7.Instance = UART7;
huart7.Init.BaudRate = 115200;
huart7.Init.WordLength = UART_WORDLENGTH_8B;
huart7.Init.StopBits = UART_STOPBITS_1;
huart7.Init.Parity = UART_PARITY_NONE;
huart7.Init.Mode = UART_MODE_TX_RX;
huart7.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart7.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart7) != HAL_OK)
Error_Handler();
void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(uartHandle->Instance==UART4)
/* USER CODE BEGIN UART4_MspInit 0 */
/* USER CODE END UART4_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_UART4_CLK_ENABLE();
/**UART4 GPIO Configuration
PA0/WKUP ------> UART4_TX
PC11 ------> UART4_RX
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF8_UART4;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_11;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/* Peripheral interrupt init */
HAL_NVIC_SetPriority(UART4_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(UART4_IRQn);
/* USER CODE BEGIN UART4_MspInit 1 */
/* USER CODE END UART4_MspInit 1 */
else if(uartHandle->Instance==UART5)
/* USER CODE BEGIN UART5_MspInit 0 */
/* USER CODE END UART5_MspInit 0 */
__HAL_RCC_UART5_CLK_ENABLE();
/**UART5 GPIO Configuration
PC12 ------> UART5_TX
PD2 ------> UART5_RX
GPIO_InitStruct.Pin = GPIO_PIN_12;
GPIO_InitStruct.Alternate = GPIO_AF8_UART5;
GPIO_InitStruct.Pin = GPIO_PIN_2;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
HAL_NVIC_SetPriority(UART5_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(UART5_IRQn);
/* USER CODE BEGIN UART5_MspInit 1 */
/* USER CODE END UART5_MspInit 1 */
else if(uartHandle->Instance==UART7)
/* USER CODE BEGIN UART7_MspInit 0 */
/* USER CODE END UART7_MspInit 0 */
__HAL_RCC_UART7_CLK_ENABLE();
/**UART7 GPIO Configuration
PF6 ------> UART7_RX
PF7 ------> UART7_TX
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Alternate = GPIO_AF8_UART7;
HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
HAL_NVIC_SetPriority(UART7_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(UART7_IRQn);
/* USER CODE BEGIN UART7_MspInit 1 */
/* USER CODE END UART7_MspInit 1 */
void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle)
/* USER CODE BEGIN UART4_MspDeInit 0 */
/* USER CODE END UART4_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_UART4_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0);
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_11);
/* Peripheral interrupt Deinit*/
HAL_NVIC_DisableIRQ(UART4_IRQn);
/* USER CODE BEGIN UART4_MspDeInit 1 */
/* USER CODE END UART4_MspDeInit 1 */
/* USER CODE BEGIN UART5_MspDeInit 0 */
/* USER CODE END UART5_MspDeInit 0 */
__HAL_RCC_UART5_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_12);
HAL_GPIO_DeInit(GPIOD, GPIO_PIN_2);
HAL_NVIC_DisableIRQ(UART5_IRQn);
/* USER CODE BEGIN UART5_MspDeInit 1 */
/* USER CODE END UART5_MspDeInit 1 */
/* USER CODE BEGIN UART7_MspDeInit 0 */
/* USER CODE END UART7_MspDeInit 0 */
__HAL_RCC_UART7_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOF, GPIO_PIN_6|GPIO_PIN_7);
HAL_NVIC_DisableIRQ(UART7_IRQn);
/* USER CODE BEGIN UART7_MspDeInit 1 */
/* USER CODE END UART7_MspDeInit 1 */
//variables need to be declared at the beginning
volatile char Rx_indx, Rx_data[2], Rx_Buffer[100], Transfer_cplt;
volatile uint8_t aTxBuffer[] = "0123456789abcdef";
void uart_task(){
MX_UART4_Init();
MX_UART5_Init();
MX_UART7_Init();
HAL_UART_Receive_IT(&huart5, Rx_data, 1); //activate UART receive interrupt every time
while(1){
// HAL_UART_Transmit(&huart4, (uint8_t*)aTxBuffer, 16, 5000);
HAL_GPIO_WritePin(RS485_DIR_GPIO_Port, RS485_DIR_Pin, GPIO_PIN_SET);
//HAL_UART_Transmit(&huart5, (uint8_t*)aTxBuffer, 16, 5000);
if (Transfer_cplt)
HAL_UART_Transmit(&huart5, (uint8_t*)Rx_Buffer, strlen(Rx_Buffer), 5000);
Transfer_cplt=0;
else HAL_UART_Transmit(&huart5, (uint8_t*)aTxBuffer, 1, 5000);
HAL_GPIO_WritePin(RS485_DIR_GPIO_Port, RS485_DIR_Pin, GPIO_PIN_RESET);
// HAL_UART_Transmit(&huart7, (uint8_t*)aTxBuffer, 16, 5000);
vTaskDelay(pdMS_TO_TICKS(1000));
printf("x");
/* USER CODE BEGIN 1 */
HAL_UART_IRQHandler(&huart5);
//Interrupt callback routine
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
uint8_t i;
aTxBuffer[0]='1';
if (huart->Instance == UART5) //current UART
if (Rx_indx==0)
for (i=0;i<100;i++)
Rx_Buffer[i]=0;
} //clear Rx_Buffer before receiving new data
if (Rx_data[0]!=13) //if received data different from ascii 13 (enter)
Rx_Buffer[Rx_indx++]=Rx_data[0]; //add data to Rx_Buffer
else //if received data = 13
Rx_indx=0;
Transfer_cplt=1;//transfer complete, data is ready to read
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
