I want to redesign a current product to make it better and more efficient.
The device is battery powered with a lithium battery (2,7 to 4.2V). A NFC reader in the circuit needs 3.3V to operate its transmitter at an optimate performance.
A STM32 will be used at 8Mhz to control the device. Since a motor, which is directly connected to the battery, will pull the battery way down, a buck-boost converter is used to created 3.3V for MCU and the rest. These Buck-Boost regulators have terrible efficiency at low power (like 50uA consumtion to put out 1uA for Sleep) i would like to avoid to power the mcu only by the buck boost.
I would like to shut down the regulator when entering sleep, and only power the STM32 at a LDO at 1.8V in sleep mode.
How can i create a dual supply concept for the STM32?
