Interesting guys, thanks.
For my setup, I have a power supply on my desk. The breakout board is connected to line and neutral (not ground). Both the powersupply and Agilent scope are connected to the same power bar on my desk, and I have a single passive scope probe. The PS is a BK Precision 1758B, which does appear to have line, neutral and ground on the
Whenever I touch the probe "ground" to the breakout board, it'll go into current limit at 0.5 amps. I should point out that removing the probe can also cause it. Also, if it's already in 0.5 amp current limit, I've never seen it recover by doing anything, including removing the probe. It's also inconsistent. Scraping the probe ground against the mounting hole seems to be worse for it. But, limiting the current to 0.1 amp causes the issue to disappear. This does sound like latch-up, as apparently there is a minimum current threshold over which latchup is self sustaining.
How can I test if my power supply is leaking from positive to ground? Or would it be leaking from line to ground on the mains side? I don't see why the scope and power supply wouldn't have their grounds together? Prehaps I will use some spade terminals to tie them together to ensure that they are properly grounded. I have definitely observed the issue with a handheld DMM.
Regardless, I've already learned things and I much appreciate the help.
A colleague has also observed the bug with a different set up.
