Author Topic: STM32F3 OPAMP in the PGA mode  (Read 2102 times)
Offline VanitarNordicTopic starter
« on: January 16, 2019, 09:03:30 am »
I have connected the OPAMP of the STM32F303 to the ADC input internally.
The opamp has two input pins. VINM and VINP. if I decided to configure it as an amplifier and select the gain (2..16) with software. it is called PGA mode.
I want to have the non-inverting amplification. then I just should connect the input signal to the VINP and the MCU itself will configure the other pin internally? I mean should I let the VINM Pin float?
Has anybody worked with this feature?
Online SiliconWizard
Re: STM32F3 OPAMP in the PGA mode
« Reply #1 on: January 17, 2019, 02:09:42 am »
Yes, the - pin is connected internally when you use the PGA mode. See p. 474+ of the ref. manual.
The following users thanked this post: VanitarNordic
