Thanks yes, the osc is set to 16MHz, so one thing we can definetely say is that the software engineer has set the conversion clock wrongly. He has set it to FOSC/2, and page 340 of the datasheet clearly says that this is not acceptable for a micro set to 16MHz.
Also, the softy has set ADACQ to 0x00...which means no acquisition time, so thats not good for us either.
Also, our softy has put in an acquisition delay, but he does this before the ADC module is actually turned ON...so this is absolutely useless.
Also, our softy is setting the ADLTHL, ADLTHH, ADUTHL, ADUTHH, ADSTPTL and ADSTPTH registers. These all pertain to the ADC module. There is no need for this. This might be having unwanted effects on our ADC reading?
Another thing we would like to do, is to discharge C(PIN) and C(HOLD) capacitors of page 347 down to ground before starting the acquisition time prior to a ADC conversion…but we are not sure how to set the ADPRE register in order to achieve this?
Sorry but does anyone know what is it that turns the sampling switch ON so that the C(HOLD) can be charged up?....does the sampling switch get turned on when the analog channel is enabled?
..or is it after the go/done bit is set?
Because our software engineer has set a variable and called it "acquisition delay".......but how does he make this happen at the right time..surely the acquisition delay is what happens after the go/done bit is set?...you cannot start this yourself.....it can surely only be started by setting the go/done bit?...and the actual value of acquisition delay can only be set in the ADACQ register, and it is up to 255* TAD?
So why has our softy made a variable called "acquisition delay"?...surely this is of no use whatsoever?
