And if you don't have a DSO, to get a stable trace on an analog scope for you to pick through, wrap that in a while(1){ ... } loop, and pulse a spare output pin before calling Wire.write, so you've got a signal that occurs ONCE per transmission block to feed to your scope's trigger input. Once you have a reliable trigger point, even with an old 50MHz 'boatanchor', as long as its got two channels and a delay timebase with a smooth-acting vernier knob, you can pick your way through the data packet bit by bit decoding it with pencil and squared paper.
Its all a lot easier with a DSO, as you can do a one-shot capture, and if its a fancy one with a protocol analyser, it can even decode the I2C bytes for you - *IF* you know how to set up that feature.
