Author Topic: Tool for converting image to binary form for storing in FPGA  (Read 3469 times)
Offline davorinTopic starter
« on: April 28, 2018, 03:02:08 pm »
EHLO (o;
Does someone know of a tool or script which can take a PNG/TIFF/whatever RGB image and convert it to a raw binary data representation for converting then to Intel HEX format which Altera Quartus accepts?
This is for testing my Verilog RGB panel driver design....
Offline Siwastaja
Re: Tool for converting image to binary form for storing in FPGA
« Reply #1 on: April 28, 2018, 04:15:08 pm »
GIMP can save a headerless RAW, just type in extension .data when saving. RGBRGB... and RRRBBBGGG formats are supported. Then, you only need to convert it to Intel HEX.
Offline janoc
« Reply #2 on: April 28, 2018, 04:20:58 pm »
ImageMagick
https://www.imagemagick.org/script/index.php
Easier to script/integrate into a build system.
« Reply #3 on: April 28, 2018, 04:24:56 pm »
Tried ImageMagick with
convert icon.png icon.rgb
but output file seemed rubbish....thought convert recognizes input/output formats automatically.
The filesize was exact though for a 64x64 rgb image..
Offline Wiljan
« Reply #4 on: April 28, 2018, 05:17:00 pm »
Irfanview does save as RAW with different options
Offline chris_leyson
  • Country: wales
« Reply #5 on: April 28, 2018, 05:32:33 pm »
Matlab or GNU Octave will do it.
Offline janoc
« Reply #6 on: April 28, 2018, 06:05:58 pm »
Use the .raw extension instead and the "stream" tool:
stream input.png output.raw
« Last Edit: April 28, 2018, 06:10:56 pm by janoc »
Offline hamster_nz
« Reply #7 on: April 28, 2018, 08:00:13 pm »
Being old-school I save in PMN format, then use a short program, that can use the attributes in the human readable ASCII  header.
Offline @rt
« Reply #8 on: April 29, 2018, 06:59:14 am »
Singe it’s an RGB panel, is there a reason not to use MSPaint to open the file, save as 24 bit MS bitmap, and then manually strip the header with a hex editor?
« Reply #9 on: April 29, 2018, 07:04:52 am »
Ah I see what the problem is...nothing to do with rgb conversion (o;
Did a small 64x64 rgb png with just a red dot on black backrground...
The generated hex file is correct and shows that the first occurrence of rad is at address 0x07CE (28):
:2007C00000000000000000000000000000002800005F00008F0000B90000DA0000F100007F
The used memory is organized as 24x4096...and when looking with the in-system memory controller....the same pattern appears at 24-bit word address:
So seems quartus messes up with the hex file when the memory is not organized as 8-bit wide..
« Reply #10 on: April 29, 2018, 07:50:11 am »
Seems there are no tools which can generate a 24-bit wide memory initialization file....
srec_cat supports mif files, but only with widths being a multiple of 8 like:
srec_cat icon.rgb -binary -output icon.mif -mif 1
srec_cat icon.rgb -binary -output icon.mif -mif 2
srec_cat icon.rgb -binary -output icon.mif -mif 4
Seems I have to split the rgb channels in 3 8-bit wide memories.
This are the commands used for generating 3 memory initialization files for Quartus:
convert image.png -separate image_%d.gray
srec_cat image_0.gray -binary -output image_0.mif -mif
srec_cat image_1.gray -binary -output image_1.mif -mif
srec_cat image_2.gray -binary -output image_2.mif -mif
« Last Edit: April 29, 2018, 08:39:40 am by davorin »
