Author Topic: [atmega 0-series] 'TCA_t {aka union TCA_union}' has no member named 'INTCTRL'  (Read 1095 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
this comes from invoking TCA0.INTCTRL which is totally valid as a variable/register name and there is a INTCTRL element to the structure TCA. All I can assume is that there is some sort of mess here with single and split operation as there are two structure setups one for each.
Offline cv007
Lookup TCA_t, INTCTRL is not there, you need to use SINGLE or SPLIT-
TCA0.SINGLE.INTCTRL
TCA0.SPLIT.INTCTRL
compiler is right and the error means exactly what is says
The following users thanked this post: Naguissa
  • Global Moderator
I see
