Thanks to all the helpful contributors to this post! Here are my conclusions for this small motorized automotive water pump used in certain 2017 Audi 2.0L TFSI equipped vehicles:
1.) The motor is a brushless DC motor, which requires a controller (onboard PCB in this case) and a Hall Effect position sensor for commutation. Because of the brushless design, the motor cannot be powered directly using only a DC source (which I confirmed).
2.) The motor assembly has a 3 connector terminals, +, - and S. The + and - terminals are presumably the DC power supply while the S is assumed to be the Signal terminal needed for the presumed LIN bus (Local Interconnect Network). This assumption is supported with Audi/VW being a member of the LIN Consortium.
3.) The PCB contains a PIC16F616 microcontroller. I am assuming this is needed to interpret and direct the commands received from the LIN bus. The most basic command being of course to turn the motor on and off. One contributor observed that there was 21k resistors at the S terminal, which he said indicated a digital input (which the LIN would be).
4.) The PCB also contains 4 MOSFET devices, one pair of IPG20N06S4L and one pair of IPD50P04P4L. It was suggested that only 3 of the MOSFETs were used in the H-bridge, while one one of the IPG20N06S4L maybe used for input protection. I assumed that an "H-bridge" would need 4 devices, but perhaps not?
5.) Most likely the motor is either on or off (my assumption). We purchased the pump as we suspected there was some type of flow shut-off capability in this coolant circuit, but the parts diagrams from the dealer did not support this and not it appears now that the pump does not have this capability.
6.) Another observation posted regarding other devices on the PCB:
• The 4 sot-6 packages are probably gate drivers.
• One of the sot-6 packages has a combi-pin. This could be the voltage regulator for the pic.
• The bottom could be loaded with an opamp and a shunt to detect stall conditions.
Wow, all for a small water pump! Keep the comments coming if you have any additional observations or expertise to share!
Thanks,
Tony
