Howardlong
But that 30 minutes is three times longer than I take to get a PIC32 up and running
Exactly,that's why i prefer the Microsticks over Pickit3. I can be naked while coding!
Hmm, it is peculiar in some way as ones get older one have less time to faff and learn yet another toolset,
yet another MCU, yet another peripheral etc. Time is everything.
I can't say I've had much problem with a PK3 supplying power, I have though had an enormous amount of difficulty in getting it working at all on occasion on MPLAB X, the USB debugger interface is truly flakey, but I can say exactly the same frustrations for NXP with their LPCLink 2/LPCxpresso and TI with their LaunchPads/CCS for different reasons.
Well, its an awful long time ago we used dsPIC's ,PIC24 and PIC32 but i recall PICkit3 had very little current to deliver out of the box. Hmm, i clearly read somewhere.....ah here the note, i might be entirely wrong as VDD_Target is delivered from USB but from Pickit3 user guide page 70 quote:
Note: The PICkit 3 programmer/debugger is powered through its USB connection. The target board is powered
from its own supply. Alternatively, the PICkit 3 can power it only if the target consumes less than 30 mA.30mA is strangely low considering it's sourced from USB.
MPLABX, aaaah well, that brings back awful memories! Did they ever fix it?
The NXP problem is the use of using too loosely integrated components that don't recover from faults without restarting most of the dev setup. With TI it turned out to be to do with the change of USB descriptor requirements from initial bootloader mode to operational mode: the device is recognised fine in its initial power up bootloader mode, but when used in CCS it attempts to re-enumerate with different USB parameters which in some heavily subscribed USB scenarios will fail. All of these scenarios take hours if not days to figure out. Hardware debuggers seem to be a continual weak link in pretty much all development environments as long as I can remember, indeed I'm always surprised when they work consistently well!
That i had no idea about! Thanks for info! In contrast ST-link works surprisingly well.
But that will be to just one ARM family or subset from one vendor: that is why I cringe about the generic use of "ARM" as if it is some kind of universal panacea. While the same cores may be the same between vendors, everything else is different. The memory layout and interfaces, boot options, peripherals etc. And CMSIS isn't the answer, that ends up being such a compromise that it's usually not worth considering except for the most trivial of tasks like a blinky.
Yes but i didn't say it was a universal panacea just that it was easy to port code in those particularly cases and that includes , suprice some of the peripherals, for example MSP430 Timers is quite similarly to ST even uses same wording for reg bits. But ofcourse it depends how complicated, convoluted ones code ,peripheral are, it also might be very difficult, we was lucky i suppose.
In the big scheme of things whether you're running a core from ARM, MIPS or a proprietary one, that is of less relevance than hard considerations such as pricing, availability, reliability, speed, power consumption, integration level and functionality, together with soft considerations such as available skill sets, familiarity and existing investment in development tools.
In general yes but many things these days can be reconsidered, development tools for instance in the same way as the absolute need for
latest Altium one can get away with P99se or ANY other depending on what the requirements is for your product or in which market segment your company/you operates in.
As an example I have a battery powered project I'm working on the uses a triple core ARM for the main processing and a PIC24 for the power control including regulation of three power domains, plus charging and on/off. The reason for the PIC24? It will run directly from 5V or a LiIon battery without regulation, plus it has a sub microamp standby. In short, couldn't find a better device for the specifications I had.
Who makes triple ARM core MCU's?
