Author Topic: Is there a way to program chip using arduino IDE without having to be root?  (Read 2499 times)
Offline Red Squirrel
I am using the arduino IDE to program a chip using an USBTinyISP but it refuses to work unless you're root.  This causes all sorts of permission issues because the folder all my files are in have different permissions than the sketch and because of Linux's limited permission system it's not as simple as just adding two users to both have permissions to the folder.     You'd think root would just have access to everything, but NFS does weird stuff.  All my data is stored on NFS, not locally.
So long story short, is there a way to set it up so I can program using the actual user that I login with?  I always end up having to execute the IDE as root so that it lets me program.
OS is Linux Mint 17.1.
As a side note, what commands does the arduino IDE invoke to program, is there a way to find out?  I imagine it depends on the chip and such.  It would be easier if I can just make a script to run that.  Optionally I could just have that script run as root but still edit the file as my regular user.
« Last Edit: July 11, 2016, 03:49:52 pm by Red Squirrel »
Online sleemanj
  • Professional tightwad.
Online blueskull
  • Country: cn
  • Power Electronics Guy
Yep, udev.
Which of those lines is suppose to work for mint 17.1?  I tried all 3 but still get the error. Does it matter what I name the file, or what the extension is?  Does it require a reboot or anything like that? (hopefully not I have too much stuff open)
Edit: Also I think I recall reading somewhere that my user has to be in the "dialout" group. I had previously did that so I am in that group.   I'm trying the last line in that tutorial as I figure Mint 17.1 probably counts as "recent ubuntu".   I also found a command "udevadm control --reload-rules" that has to be run after making changes. So I tried that as well.
Edit2: So I bit the bullet and rebooted.  Still not working.  Anything else I can try?
« Last Edit: July 11, 2016, 04:21:54 pm by Red Squirrel »
Got it!
Turns out I have to name the file with the .rules extension.
Online sleemanj
File > Preferences > Show verbose output during: compilation, upload
Commands executed are placed in the console output area.
The following users thanked this post: oPossum
Thanks!  That's great to know.  I eventually want to just script this so it's easier.   i eventually want to learn to code the chips without relying on arduino, but baby steps. :P  Just so much easier to find info online by searching "[what I want to do] arduino".
Offline Mechatrommer
  • Country: my
  • reassessing directives...
if its the same as windows, and it should be. Arduino ide will invoke avrdude.exe with arguments like board/chip type (selected from menu),port number,temp file path to hex output and such.. which in turn the avrdude will program the board through the comm channel,usb or what..to see how exactly the argument looks like, you can build dummy middleman avrdude and temporarily replace the original avrdude,otherwise look out for help file that i'm not sure where. fwiw..
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
The Future is Now, Breaking the GHz Barrier... (Lecroy DDA5005 5GHz 20GS/s XXL)
Online sleemanj
Or, as I wrote above, turn on verbose output, then you see what commands get run, with all their arguments.  No middleman required.
The following users thanked this post: Kilrah
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
sudo addgroup --system usb
echo SUBSYSTEMS==\"usb\", GROUP=\"usb\", MODE=\"664\" | sudo tee -a /etc/udev/rules.d/00-usb.rules
for each in usb tty dialout; do sudo usermod -aG $each $(whoami); done
sudo reboot
Create a new system group called "usb", add yourself into it (as well as groups "tty" and "dialout" so you can access serial ports too,) add a udev rule to make all USB devices owned by the "usb" group, and finally reboot to make it all work.
Ohhh I like that one better, so it will work for everything USB and not just that specific one?  I'll have to try that out.
Offline Mr J
    • Facebook mjssvt
I just ran into this myself with Ubuntu 14 not sure about mint, there are a couple of ways depending on version
http://mightyohm.com/blog/tutorials/avr-toolchain-installation/linux/ for (version 10 and lower)
http://feedback.codebender.cc/knowledgebase/articles/387072-how-to-use-usbtinyisp-programmer-in-linux (Version 12 and 14 and 16)
Mr J, N1IR
Offline Mr J
    • Facebook mjssvt
yea ever since Arduino 1.0 you need to change permission to access the USB
