Author Topic: USB HID Enumeration  (Read 10210 times)
Offline aandrew
Re: USB HID Enumeration
« Reply #25 on: February 23, 2017, 11:38:05 pm »
I have no idea. I would strongly suggest to use Linux for debugging USB devices. Linux is way more descriptive with what's wrong with the device.
Not to mention it has a *great* built-in USB traffic logging and debugging system: https://www.kernel.org/doc/Documentation/usb/usbmon.txt (Wireshare also works with this interface, although I've not used it myself.)
Offline BamburTopic starter
« Reply #26 on: February 24, 2017, 04:10:30 pm »
H-m, we might take our words back on bidirectional data endpoints:
Data endpoints are optional and used for transferring data. They are unidirectional, has a type (control, interrupt, bulk, isochronous) and other properties.
https://msdn.microsoft.com/en-us/library/windows/hardware/dn303353(v=vs.85).aspx
« Last Edit: February 24, 2017, 04:12:51 pm by Bambur »
Online ataradov
    • Personal site
« Reply #27 on: February 24, 2017, 04:44:00 pm »
I think they just used the wrong words. Technically, for endpoint 5, IN direction will have address 0x85, and OUT direction will be just 0x05, so they are unique in a way.
Otherwise, I see no reason to not support the same index for IN and OUT endpoints.
Alex
« Reply #28 on: March 08, 2017, 02:17:36 pm »
Alex, thanks again! I see your point.
Next I would like to ask about the considerations on a protocol over interrupt IN and OUT endpoints.
I have understood host polls an IN endpoint periodically and has an internal ring buffer where it stores fetched HID reports. Hence, there is HidD_SetNumInputBuffers on Windows, for instance. Nevertheless, there is no guarantee no report(s) will be lost.
Have you thought about that? Any solution?
Online ataradov
    • Personal site
« Reply #29 on: March 08, 2017, 04:43:20 pm »
Not really. PCs are much faster than any USB device out there. Just organize your program in a way that reads the data fast enough.
With USB FS it is not a problem at all, since your maximum throughput is 65 KB/s. With USB HS I was getting something like 6 MB/s, which is also close to theoretical maximum, ans I had no problems with that.
Alex
Offline janoc
« Reply #30 on: March 08, 2017, 05:09:54 pm »
BTW, careful with the HID descriptors - the Windows HID parser is notorious for crashing and randomly barfing on otherwise perfectly valid descriptors that Linux or Mac will work fine with (for example). The best way that I have found to avoid this issue is to "steal" a descriptor from a device implementing similar functionality to what you are after and adapt it - that will give you a known working starting point.
If you don't have an USB analyzer, then Wireshark (https://www.wireshark.org/) can capture and analyze USB transactions too if you install the USBCap drivers during installation. That is a huge timesaver for debugging problems like this.
For interfacing with HID devices in a portable way without having to deal with the messy Win32 APIs I have found the HIDAPI lib (http://www.signal11.us/oss/hidapi/) indispensable. That makes talking to a HID device a lot easier.
« Last Edit: March 08, 2017, 05:13:16 pm by janoc »
Offline janoc
« Reply #31 on: March 08, 2017, 05:17:43 pm »
I second this. Even if you put Linux in a VirtualBox image, it will save you a ton of headaches.
