Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
USB JTAG for FPGA Configuration
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: USB JTAG for FPGA Configuration (Read 1664 times)
electosleepy
Contributor
Country:
on:
January 26, 2016, 03:10:42 am »
I've seen that the FT2232H is a popular IC for FPGA programming and debugging. The schematic for the Scarab miniSpartanr6+ for example uses one channel for JTAG and another channel for a FIFO interface described on page 41 of the FT2232H datasheet. Why would you choose FIFO over UART, I2C, or SPI. What is the FIFO channel responsible for? Is it used to write bitstreams to flash memory?
miniSpartan6+ schematic.
https://github.com/scarabhardware/miniSpartan6-plus/blob/master/miniSpartan6%2B_Rev_B.pdf
FT2232H webpage.
http://www.ftdichip.com/Products/ICs/FT2232H.html
FT2232H datasheet.
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT2232H.pdf
Logged
baoshi
Regular Contributor
Country:
Re: USB JTAG for FPGA Configuration
Reply #1 on:
January 26, 2016, 03:48:32 am »
These kind of application is usually meant for SPEED through USB2.0 port. FT2232H FIFO gives you full 480Mb/s throughput while SPI in sync mode only gives 30Mb/s
Logged
electosleepy
Contributor
Country:
Reply #2 on:
January 26, 2016, 04:35:19 am »
So once the FPGA is programmed through JTAG, I can transfer the bitstream data through the FIFO channel to the flash memory so it can reconfigure itself if the power is disconnected?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
