Author Topic: USI-I2C / USI-SPI on AVRs  (Read 2687 times)
Offline dannyfTopic starter
« on: December 01, 2015, 03:26:46 pm »
As part of the HX711 milliohm meter project, I worked out a few modules that allow serial communications (I2C/SPI/USART) on the ATtiny85 utilizing its USI peripheral. Have to say that they are not that intuitive to use, and are far slower and less flexible than PIC's MSSP modules.
Offline westfw
Re: USI-I2C / USI-SPI on AVRs
« Reply #1 on: December 02, 2015, 09:42:19 am »
Yeah; I looked at Atmel's App Note on doing a UART with USI, and I wasn't very impressed :-(
The SERCOM peripheral in their ARM chips looks ok, though.
Offline Psi
« Reply #2 on: December 02, 2015, 10:42:22 am »
not much point using a ATtiny unless you have no choice. Use an ATMega with proper UART SPI TWI port. (or save some money and use a stm32  :-DD )
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #3 on: December 02, 2015, 05:51:29 pm »
I agree that PIC peripherals are generally easier to use. However until recently no 8 pin PIC had hardware SPI, I2C or UART (only the 12F1822 and 12F1840 have all three). At the same clock speed PIC code is 2-4 times slower than AVR, so it needs more peripheral hardware to keep up.
Try doing this:-
on an 8 pin PIC!
Offline ralphd
    • Nerd Ralph
« Reply #4 on: December 02, 2015, 06:02:11 pm »
Doing SPI on USI is pretty easy, but UART is a hack since the bitorder needs to be reversed, and the 8bit limit means spitting up 8N1 transmissions.  If you only need tx, bitbanged UART can be done in under 30 bytes of asm.
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline Psi
« Reply #5 on: December 03, 2015, 11:29:14 am »
Try doing this:-
on an 8 pin PIC!
haha, that made my day
So awesome
bitbanging ethernet  :-DD
« Reply #6 on: December 05, 2015, 12:58:25 pm »
Try doing this:-
Really nice. Can be done with USI as well.
