Continually pushing an argument towards the way an RTOS, which is built to handle interrupts in a pre-specified way, or on Itanium and x86 micro
processors primarily used with an OS is... what it is.
An RTOS is another additional layer that is already built to handle interrupts in a certain, limited way. Of course the use of interrupts will be more limited. And being built to handle parallel tasks to begin with, of course using the RTOS tools to handle events is more appealing.
If you are have direct control over interrupt handling on your device, interrupts can be very broadly useful. You could implement interrupts for a specific application/task, rather than set up a handling algorhithm that works for a general purpose OS. TerminalJack pretty much covered it, and yet the hand keeps trying to talk to the face.
Of course if the discussion is limited to a subset of embedded systems...
is necessary context to make some of the posts on this thread sensible. Mostly yours.
OP: can we keep this limited to 8 bit microcontrollers through single core ARM, for instance?
- Well, sure, you don't need interrupts if you use a 32 core XMOS processor. And if you need to use interrupts you chose insufficient hardware.
The truth is that you're comparing XMOS architecture to a typical RTOS. (Even among RTOS's, there are different ways of managing multithreading and interrupts.) XMOS architecture and extended language can result in a shorter and more predictable latency than a given
RTOS running on a single or multi core processor. This is because an RTOS on a multicore processor is doing the same thing, only it's fixed in one method of doing so. The XMOS extended language gives users the access to spinlock/loop and handle interrupts as they see fit for a given task/s. So the interrupt latency can be shorter and more predictable in this case because you're not fixed to a specific RTOS, which may be written with different priorities. Even (especially) with a single core, use of interrupts can be done with extremely short latency and high predictability... depending on the application and/or use (or non-use) of an OS. I imagine that in many specific applications, a single core micro using interrupts can be faster and more predictable even than an XMOS, given the same processor speed. If your app doesn't make good use of multiple cores, maybe you are choosing
overadequate hardware. Is XMOS superior at multithreading than any given RTOS? More flexible, it sure seems. But some apps don't benefit from multithreading. For some hardware applications, interrupts are ideal.
I'll put it this way. For certain applications, using a certain, adequate single-core device, one MIGHT be able to accomplish said task satisfactorily using code loop polling. And to achieve this, you MIGHT need to be a genius or a masochist. Whereas if you cannot do said task better (lower and more predictable latency) with an interrupt, you would have to be a moron.
