I use the Eclipse
at the beginning I was interested because enthusiast of such of tools and IDE, after a very bad job experience with
Windriver and their
Workbench (which is based on Eclipse) my feelings changed and now I
hate those hyper complex tools, and this is the main reason why I wrote my own tool: with Eclipse I have always been doomed with metafiles and other stuff, not mentioning that those tools (Eclipse and something that is based on its source) are also too slow on my laptop(1)
with "too slow" I means that it makes me annoyed, delays are in order of seconds
and, in my experiences, when it failed with metadata ... I lost the whole project, wasting a lot of time to figure out what was wrong without finding an answer, therefore the only solution I found was a brutal "erase and rewind"
- delete the whole project (except source files)
- click on "new project", attach source files, and start to describe it from the scratch
veditor plugin to write VHDL because it is 1000 times better than the crummy editor in ISE
ISE looks very comfortable once integrated with
Scriptum by HDL Works (there is a freeware edition)
it's a pure HDL editor with syntax highlighting, no other special features (unless you buy the full version)
anyway it's very comfortable, and it's able to track the line error if used with ISE
ghdl is still missing a good error report engine (on Sigasi's blog people also reported the same comment about it), sometimes it's not clear *WHAT* is wrong and *WHERE*, but you can ask ISE to give you an hand, ISE's checker (syntax and semantic) can be set to be very fussy, which is useful
and in case of error it invokes
Scriptum which is able to track me back to the code's line
(1) WindowsXP/32bit +CoNix, cooperative unix under Windows, running gentoo/x86
hw specifications, intel i2@1.6Ghz, with 2Gbyte of ram
