Author Topic: Vivado HLS in action.  (Read 5821 times)
Offline hamster_nzTopic starter
« on: December 12, 2015, 05:26:32 am »
Given that I installed a Vivado HLx Webpack license I thought I should at least try it.
Given that I love fractals on FPGAs, I tried this:
unsigned char mandelbrot(double cx, double cy) {
  int i = 0;
  double x = cx, y = cy;
  while(i < 255 && x*x+y*y < 4.0) {
    double t = x;
    x = x*x-y*y+cx;
    y = 2*t*y+cy;
    i++;
  return i;
I set that I wanted it to run at 100MHz.
It took 7 seconds to convert from C into both VHDL and Verilog.
Usage is:
0 memory blocks
25 DSP blocks
1273 Flipflops
1358 LUTs
Detailed stats were...
Latency: 30 to 7662 cycles
Iteration Latency: 30 cycles
Trip Count: 1-255 cycles
Pipelined: no
I changed the inputs to 'float's, and the usage went to 22 DSPs,  1,611 FFs, and 1,733 LUTs, total latency is 30 to 7407 cycles and iteration latency went down to a slightly faster 29 cycles.
This is the top level interface for the 'float' version (the 'double' version just had wider 'cx' and 'cy'):
entity mandelbrot is
port (
    ap_clk : IN STD_LOGIC;
    ap_rst : IN STD_LOGIC;
    ap_start : IN STD_LOGIC;
    ap_done : OUT STD_LOGIC;
    ap_idle : OUT STD_LOGIC;
    ap_ready : OUT STD_LOGIC;
    cx : IN STD_LOGIC_VECTOR (31 downto 0);
    cy : IN STD_LOGIC_VECTOR (31 downto 0);
    ap_return : OUT STD_LOGIC_VECTOR (7 downto 0) );
end;
I didn't perform any HLS-level place and route on the IP, which would have taken I guess 15 minutes, given that a design with 640 DSPs and 100k LUTs takes a couple of hours).
So I guess the question is this:  Is 300ns for a double precision complex MAC, implemented  in hardware any good?
« Last Edit: December 12, 2015, 05:30:06 am by hamster_nz »
Offline autobot
Re: Vivado HLS in action.
« Reply #1 on: December 16, 2015, 01:13:32 pm »
Interesting.What does it mean in ops/sec?
Also why not pipelined ? should increase performance.
« Reply #2 on: December 16, 2015, 07:16:58 pm »
At 100MHz,it works out at about 33M ops/per sec, as each pass is about 10 simple operations.
So I turned on pipelining, using the required pagama statement:
unsigned char mandelbrot(float cx, float cy) {
  int i = 0;
  int j = 0;
  float x = cx, y = cy;
#pragma HLS PIPELINE
  for(j = 0; j < 256; j++) {
  if(x*x+y*y < 4.0) {
  double t = x;
  x = x*x-y*y+cx;
  y = 2*t*y+cy;
  i++;
  return i;
I can now drop an item into the pipeline every cycle (for about 256,000 ops per second) - however, it uses 9443 DSP slices, 622,247 FFs, and 612,810 LUTs - a huge amount of resources.
My hand-written implementation does about 192,000M ops per second, with usage of 680 DSP blocks, 158,261 FFs, and 99.568 LUTs (with 20% of the DSP blocks implemented in LUTs).
The reasons for the improved efficiency of the hand-written design are quite varied, but mostly structural.
  • I 'triple-pump' the pipeline, reducing the pipeline length by 2/3rds. It runs at 225 MHz generating pixels at 75MHz, with each pixel passing through the entire pipeline three times.
  • The HLS design uses 32-bit floating point on the external interfaces, but internally it appears to do the maths as doubles and then truncate it. I use a 36-bit fixed point (with a range of  +8 to -8) - perfectly matching the problem.
  • I've pipelined to match the requirements of the underlying hardware, allowing the design to meet timing at 225MHz, The HLS design's pipelining looks to match the scheduling of the C code's operations.
However, I have spent a very long time on my design, a lot longer than the hour playing with the HLS tool
« Last Edit: December 16, 2015, 10:59:18 pm by hamster_nz »
Offline autobot
« Reply #3 on: December 16, 2015, 08:20:32 pm »
Vivado HLS has decent support for arbitrary precision, looks easy to use:
http://www.xilinx.com/support/documentation/application_notes/XAPP1173-carrier-loop.pdf  - pg 9.
« Last Edit: December 16, 2015, 08:23:32 pm by autobot »
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: December 16, 2015, 09:01:09 pm »
thought about restructuring code ?
  int i = 0;
  int j = 0;
 float xx,yy;
   xx = x*x;
   yy = y*y;
   if((xx+yy) < 4.0) {
    double t = x;
    x = xx-yy+cx;
    y = 2*t*y+cy;
    i++;
  return i;
« Reply #5 on: December 17, 2015, 05:35:05 am »
  int i = 0;
  int j = 0;
 float xx,yy;
   xx = x*x;
   yy = y*y;
   if((xx+yy) < 4.0) {
    double t = x;
    x = xx-yy+cx;
    y = 2*t*y+cy;
    i++;
  return i;
Much to my surprise, it uses more resources!
Original pipelined  Refactored Pipeline
DSP                  9,443    9,443
LUT                622,247       767,457
FFs                612,810       667,491
If I get a chance to night I'll play around with the fixed precision stuff and see how that works out (it should be much better...)
« Reply #6 on: December 18, 2015, 12:40:28 am »
I did have an attempt at using the fixed point data types. Not sure if I did it correctly:
#include <ap_fixed.h>
typedef ap_fixed<35,4,AP_RND > fixed_4_31;
unsigned char mandelbrot(fixed_4_31 cx, fixed_4_31 cy) {
  int i = 0;
  int j = 0;
  fixed_4_31 x = cx, y = cy;
  fixed_4_31 xx,yy;
   xx = (float)x * (float)x;
   yy = (float)y * (float)y;
   if((xx+yy) < 4.0) {
    fixed_4_31 t = x;
    x = xx-yy+cx;
    y = 2*(float)t*(float)y+(float)cy;
    i++;
  return i;
Resources are now 3576 DSP blocks, 587,441 FFs and 577,500 LUTs. This is pretty close to what it should be for fixed point (as a single-cycle 35-bit multiplication requires 4 DSP blocks).
It starts becoming more and more divergent from standard C...
