Author Topic: What is the different of Arduino as ISP and AVRISP?  (Read 1592 times)
Offline Porama6400Topic starter
  • Country: th
« on: August 29, 2016, 01:09:14 pm »
If i want to program Atmel microcontroller from Atmel Studio
Should I buy actual AVRISP or Arduino as ISP is enough?
And how is it different?
Offline Rithers
Re: What is the different of Arduino as ISP and AVRISP?
« Reply #1 on: September 02, 2016, 05:35:49 pm »
If you already have an Arduino, give 'er a try as an ISP.   Arduinos are nice in that they have built-in power and serial adapter,
however it might not provide the same "plug & play" ISP functionality as a device which is fully supported in Atmel Studio.
(Maybe Arduino's AVRISP is supported in Studio 7 by now, im not sure...)
You might end up having to copy some AVRdude commands from Arduino's verbose output window into AtmelStudio's external tool UI.
At the very least, you'll learn some fun stuff.
-If you havent yet seen it,  this book is really amazing (I call it my AVR bible):
AVR Programming"learning to Write Software For Hardware"
Elliot Williams
http://shop.oreilly.com/product/0636920028161.do
https://www.amazon.com/AVR-Programming-Learning-Software-Hardware/dp/1449355781
takes you through real basics like flashing an AVR from your command line terminal onward through some very interesting in-depth projects
happy Flashing
/rithers
Offline dannyf
« Reply #2 on: September 03, 2016, 01:15:05 pm »
depending on what you meant by "program":
1. if you want to burn code into AVRs from within AS, get a programmer that's supported by AS;
2. if you want to burn code compiled from within AS, get a programmer to your liking.
depends on what you have. I used the dragon and now I'm using mostly usbasp: fast, robust, small and cheap. But if you have an arduino already and are tight on money, a programmer that reuses your arduino makes perfect sense.
