Author Topic: Which device do I need to read out a PIC18F8720 with ICSP?  (Read 2832 times)
Offline KjeltTopic starter
« on: November 19, 2013, 09:11:07 pm »
Hi, I am not very familiar with Microchips PIC controllers so probably a beginners question for some of you.
I have multiple commercial devices with different firmware versions that I would like to check if I can read them out (small chance probably but hey I can give it a try) and flash them all with the latest firmware.
What is the cheapest device available to read out a PIC18F8720 with low voltage ICSP?
Thanks in advance people for the help :-+
Offline Hideki
  • Country: no
Re: Which device do I need to read out a PIC18F8720 with ICSP?
« Reply #1 on: November 19, 2013, 09:49:57 pm »
Microchip PICKIT 3 is the standard cheap tool, but you can probably get an ever cheaper clone from china if $45 is too much.
« Reply #2 on: November 19, 2013, 10:19:49 pm »
Ok thanks would the predecessor (pickit 2) also work? I might be able to lent that from a colleague.
Offline Hideki
  • Country: no
« Reply #3 on: November 19, 2013, 10:30:45 pm »
yes
Offline amyk
« Reply #4 on: November 20, 2013, 08:41:24 am »
You can do it with a few wires and a parallel port... ditto for the AVRs.
Offline kayvee
« Reply #5 on: November 20, 2013, 08:48:52 am »
It's highly unlikely that you will be unable to do that as the norm is to enable the code protection fuse after programming to prevent just that.
I have yet to see a commercial product where the code protection has not been enabled.
« Reply #6 on: November 20, 2013, 09:21:57 am »
Ok thanks all! I will ask the Pickit2 from the colleague since I don't have a PC with parallel port anymore  :-[ .
It's highly unlikely that you will be able to do that
You're probably right, but I just have to check it out, there is always a (small) chance.
