Author Topic: Why does the PIC slow down when I connect some current loads?  (Read 2300 times)
Offline Tricka90Topic starter
« on: October 09, 2013, 08:02:40 am »
I'm making a PIC controlled LED lamp. I'm noticing that every LED I add to the circuit the PIC program slows down more. Why is it happening and how can I work around this problem?
I'm using a PIC 16F876 with 12MHz chrystal oscillator.
If you need more information I'll be happy to give them.
Offline ve7xen
    • VE7XEN Blog
Re: Why does the PIC slow down when I connect some current loads?
« Reply #1 on: October 09, 2013, 08:31:08 am »
Are you changing the code when you add an LED? If the PIC is clocked from a crystal it won't appreciably change speed just because you've changed the load on its IO pins. Something in your code has changed, or is behaving differently, when you're adding the LEDs.
Posting your code may help.
73 de VE7XEN
He/Him
Offline dannyf
« Reply #2 on: October 09, 2013, 10:30:36 am »
You must be living in an alternate universe, :).
Seriously, what exactly did you observe that led you to  that conclusion?
Offline Psi
« Reply #3 on: October 09, 2013, 10:46:18 am »
My guess is he's doing some sort of matrix or pwm
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #4 on: October 11, 2013, 08:19:06 pm »
If you are running from internal oscillator, or any other external crystal which requires schmitt triggering, and the LED's are directly on the pic pins you might be exceeding maximum current limits.
Causing voltage drop, causing oscillator artifacts.
Offline WarSim
« Reply #5 on: October 11, 2013, 10:17:34 pm »
I agree with your assessment.  All PIC FRCs have voltage for speed requirements.  You may be browning out the chip slowing the FRC OSC or even triggering the BOR whenever you turn on too many LEDs.  Either way it is starving for attention (pun).  :-)
Offline dannyf
« Reply #6 on: October 11, 2013, 10:35:25 pm »
Yes, likely polling.
