How is that a breakout board? It is a PCB with all of the extra components and connectors needed for the full project. Plus I get the advantage of being able to accomplish mechanical tasks to on the board and include silkscreen to document/brand it.
What does, say, arduino UNO have except MCU, vreg and crystal that may actually be used for operation of your circuit based on arduino?
All of the wires that are not plugging into a connector are replaced by TRACES on the PCB.
LOL what? You just leave unused MCU pins unconnected.
It is not like I am just pinning out all of the atmegas pins and making my own crappier version of an arduino and then still putting 100 wires on it.
Do you live in alternate reality? If you don't use some MCU pins, you leave pads unconnected. If you do use them, there do not become less wires if you use arduino.
I have no idea what you are talking about. From your logic, it seems that any board that uses an ATMega is an arduino.
Here is a partial parts list of a typical board I make, most of these parts are not on an uno.
ATMega328P (yep, the one used on an uno you got me)
6 5v relays
6-12 transistors
PTCs on outputs
zener/tvs diodes on inputs
L293D
7805
dozens of passive and diodes
Note, I don't use a crystal on most of my boards because the internal 8MHz clock is more than enough for me. I also don't use USB serial and if I use serial it is with a MAX485 to another board.
Pretty much all of these things could be accomplished by buying modules on ebay and putting tons of wires between them all. I don't know what you are arguing, but my point was that a PCB gets rid of all of those wires. Plus if it warrants it I can have mounting holes for switches ect in the PCB to eliminate the wires going to those too. I think the unified design and lack of wires looks a lot more professional and is less prone to mistakes then a jumble of wires connecting ebay modules.
