The sound hardware includes:
* One 8-bit parallel DAC with latched input,
* One 16-bit reloadable counter,
* Two 16-bit latches,
* One channel on the PIT.
* One channel on the DMA,
* Glue logic
This sound hardware have twomodes of operation: PIO and DMA.
In the PIO mode, the DAC is addressed directly by the processor through its I/O port. The counter and latches are unused, and the PIT channel is disabled.
In the DMA mode, the two latches are used to store the beginning and ending pointers of the audio buffer in the memory, and the PIT channel is used to set the sampling rate. When the PIT fires the sound hardware generates a DMA request, pulling one sample off the main memory, and shoves it to the DAC. The counter is loaded with the beginning address (in latch A) when either its value is equal to the ending address (in latch B), or when latch A is being written to, or when the counter itself is being written to.
