Author Topic: yacc expert? rule useless in parser due to conflicts  (Read 458 times)
Offline legacy
« on: February 11, 2019, 09:52:37 am »
prog:   lines
lines:                                  { list_line(); unknown = dcflag = 0; }  /* reset flags */
                | line                  { list_line(); unknown = dcflag = 0 ; } /* on every new line */
                | lines '\n'    { list_line(); unknown = dcflag = 0; }
                | lines line    { list_line(); unknown = dcflag = 0; }
                | lines error   { list_line(); unknown = dcflag = 0; }
line:
                | defsym                                                /* define symbol (label) */
                | stmnt                                                 /* opcode */
                | defcon                                                /* build-in defines */
                | skip                                                  /* comment... */
                | prepro                                                /* preprocessor command */
                | END '\n'              { return(0); }
ass_pars.y:78.5: warning: rule useless in parser due to conflicts [-Wother]
 line:
cannot understand what is wrong  :-//
the Bunker is open!
(shortcut)
Offline sokoloff
Re: yacc expert? rule useless in parser due to conflicts
« Reply #1 on: February 11, 2019, 10:29:12 am »
I'm no yacc expert (and that's putting things mildly!), but I think your problem is that you have one too many "or"s in both lines and line, which makes for an ambiguous grammar.
Try this:
%token defsym stmnt defcon skip prepro END
%%prog:   lines
line:
Offline sokoloff
« Reply #2 on: February 11, 2019, 10:44:25 am »
Thinking about it a bit more, you might want to allow a line to be empty, but not a lines.
(And since a lines could just be a line, you'll get the same end result, but without the grammar ambiguity.)
Offline rhb
« Reply #3 on: February 11, 2019, 10:54:28 am »
For openers that is not valid syntax.  That section should be enclosed by  lines which read:
your stuff
Besides that you have not defined your tokens;
rhb@Hipster:/export/home/rhb/wrk/yacc$ yacc tst.y
"tst.y", line 21: fatal: undefined nonterminal: defsym
"tst.y", line 21: fatal: undefined nonterminal: stmnt
"tst.y", line 21: fatal: undefined nonterminal: defcon
"tst.y", line 21: fatal: undefined nonterminal: skip
"tst.y", line 21: fatal: undefined nonterminal: prepro
"tst.y", line 21: fatal: undefined nonterminal: END
Try this:
prog:   lines
line:
1 rules never reduced
conflicts: 20 shift/reduce, 4 reduce/reduce
That's pretty typical output.
I have not used lex and yacc in 27 years, so to say I'm rusty would be an understatement.  In fact, about this time 27 years ago I was wrapping up 6 weeks spent learning lex and yacc..
A few weeks later I got my first contract job with a major oil company.  As it happened my first assignment was a parser.  I finished it in 2 weeks working about 1/2 time and doing other things the rest of the time.  The project leader had allocated 2 months for the parser.  From then on I walked on water.
What are you using for a reference?  "The Unix Programming Environment" by Kernighan and Pike has a good intro to lex and yacc.   I have several feet of books on compilers, regular expressions, parsers etc.  So I can only guess what I used 27 years ago besides K&P.  But these look likely:
Introduction to Compiler Construction with Unix
Schreiner & Freeman
Lex & Yacc
Levine, Mason & Brown
I strongly urge you to work through the 4 banger calculator in K&P.
Offline legacy
« Reply #4 on: February 11, 2019, 11:32:57 am »
The above is not the complete source, it's too long.
prog:   lines
line:
Now, it compiles without working (it seems sensible to TABs), but the whole source.y needs to be rewritten in a neat way.
# make
yaccompiling ass_pars.y
compiling ass_pars.c
compiling main.c
compiling misc.c
compiling symbol.c
compiling ass_lex.c
building out/as11
it's an assembly compiler. For the next project, I will consider above-suggested books.
Thanks, guys  :D
the Bunker is open!
(shortcut)
Offline sokoloff
« Reply #5 on: February 11, 2019, 11:43:22 am »
Don't start every rule with a pipe.
Right now a "nothing" matches both the lines and line rules. You don't want that.
I think you might also want to allow a blank line to be a line (and so it would match as a lines and a line and not a lines and a '\n', thereby deleting the lines '\n' rule)
Offline rhb
« Reply #6 on: February 11, 2019, 03:02:50 pm »
It's *not* a pipe. BNF notation is *not* the Unix shell!!!! The "|" is an "or" in yacc.
 It's an allowed instance.  In regular expression notation it's the equivalent of '(A|B|C|D)'  written differently.
Offline sokoloff
« Reply #7 on: February 11, 2019, 11:55:31 pm »
It's *not* a pipe.
It sure as hell is a pipe character! That it's not a Unix pipe (nor a copper pipe) is irrelevant.
No shit; really? I had no idea. I must have just accidentally mistyped when I called it an "or" in my first response, which then seemed to be not clearly understood, so I called the character in concern a "pipe" in the later response to draw attention to the change I made to eliminate the ambiguous grammar rule warning:
Agreed (and previously understood). The concern is that the rules above have (|A|B|C|D) being a "lines" and (|E|F|G|H) being a "line", with the leading empty case on both, which leads to ambiguity in the grammar.
Offline legacy
« Reply #8 on: February 12, 2019, 12:48:06 am »
prog:   lines
lines:
         /* empty line */      { list_line(); unknown=0; dcflag=0; }
//      | line                 { list_line(); unknown=0; dcflag=0; }
        | lines '\n'           { list_line(); unknown=0; dcflag=0; }
        | lines line           { list_line(); unknown=0; dcflag=0; }
        | lines error          { list_line(); unknown=0; dcflag=0; }
line:
        | END                   { return(0); }
//      | END '\n'              { return(0); }
does this look better? it compiles without warning, and the resulting compiled module passes all the test cases.
; do you like a comment?
PORTA           equ             $00                             ; Port A Date Register
PACTL           equ             $26                             ; Port A Control Register
SPCR            equ             $28                             ; Control Register
BAUD            equ             $2b                             ; SCI Baud Rate Register
SCSR            equ             $2e                             ; SCI Status Register
SCDAT           equ             $2f                             ; SCI Date Register
HPRIO           equ             $3c                             ; Mode Register
offset          equ             $a0                             ; start
len                     equ             $a2                             ;
                        org             $0000                   ;
getbyte         brclr   #$20,SCSR,x,*   ;
                        ldaa    SCDAT,x                 ;
                        staa    0,y                             ;
                        ldaa    0,y                             ;
                        iny
                        brclr   #$c0,SCSR,x,*   ; Tranceiver Ready
                        staa    SCDAT,x                 ; Echo
                        rts
delay           ldy             #$ffff
delayloop       dey
                        nop
                        bne             delayloop
                        rts
                        end
The grammar understands the source, and the compiler is correctly able to compile it.
(yes, I know there is GNU AS, GAS/11, but it's not directly compatible with Motorola Macro Assembly/11)
the Bunker is open!
(shortcut)
Offline sokoloff
« Reply #9 on: February 12, 2019, 01:04:23 am »
Yup looks good.
Good deal!  :-+
Offline legacy
« Reply #10 on: February 12, 2019, 08:09:01 am »
it has a defect
this works
org       $0000
 anda    #$00
 end
this does not work
org       $0000
anda    #$00
end
file guineapig2.s (1): syntax error
org       $0000
lines must begin with a space, otherwise the yy_lex doesn't work correctly.
the Bunker is open!
(shortcut)
