Author Topic: kicad via stitching being wierd  (Read 3300 times)
Offline hazukiTopic starter
« on: December 10, 2014, 08:35:16 pm »
Hi all. I am trying to stitch two planes together in Kicad. It seems rather intuitive and works properly. However, after working on another part of my PCB, I come back to the area that I've just stitched and all of a sudden the pour around the vias are removed, effectively isolating them. This problem keeps happening to me, and I don't know why. Anyone have the same issue? Both planes are on the exact same net. Here's an image of my recurring problem:
Thanks!
Offline kingofkya
Re: kicad via stitching being wierd
« Reply #1 on: December 10, 2014, 09:01:07 pm »
When you start make sure the first node is connected to a real pin for example the D pad on the transistor/fet.
When the ground plan is regenerated or DRC is checked, it destroy the original copper flood and the track/vias are disconnected form any net. Then it is regenerated resulting in what you have here.
I know really annoying.
Offline c4757p
  • adieu
« Reply #2 on: December 10, 2014, 09:38:16 pm »
Are you on one of the old versions, or a recent testing build? If the latter, shut off DRC, manually reconnect the via, and then re-import the netlist.
As king says, tracks don't always keep their net associations; they have to be anchored to something with a netlist-defined net.
« Reply #3 on: December 10, 2014, 09:47:49 pm »
King,
Thanks, you've solved my problem. Kind of annoying, but I can deal with it.  :-+
