Author Topic: i Need help in designing PIC16f877a based development board  (Read 2398 times)
Offline samdareTopic starter
  • Country: in
hey there, i need a schematic for designing development board PCB for PIC16f877a  using following stuff in circuit.
-PIC controller -atmega8a burner
-9 leds
-9 push buttons
-motor driver L293D
-2 small buzzer
-2 seven segment
-1LCD
-2ADC pin
-1main circuit switch on off circuit
-1 AC jack
-+9v dc
-1LED FOR CIRCUIT on off status indication
-1 7805 Voltage regulator
- USB connector with driver
-as comfortable male female pins
somebody help me with schematic ,rest all i can .Is there some open HARDWARE project out with more or less similar things.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: i Need help in designing PIC16f877a based development board
« Reply #1 on: March 30, 2018, 05:16:17 pm »
You mean you want someone else to do all the work for you, is this homework? Please don't double post, it causes confusion and annoys people.
