Author Topic: interfacing with a commonly available cheap 2-channel PWM PCB module (no name)  (Read 1622 times)
Offline n3rdx
Hello all. I recently purchased an Ebay common item (too many variants of the same product) which is pictured below (from the Ebay posting) and has a silk screen part number HW-1015. I have however seen many other websites/product listings of the same product in order to use the serial commands shown in the posting. I am trying to interface with it using the "serial" interface, with no luck. Does anyone have any tips/experience with what type / level of serial interface to use? The MCU is reported to be stm8s003k3, but I haven't verified it.
What kind of USB/serial interface do you recommend I use?
eBay auction: #https://www.ebay.com/itm/2CH-Independent-PWM-Generator-Duty-Cycle-Pulse-Frequency-Module-LED-Digital-Tube/112150422354?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
http://www.icstation.com/channel-pulse-adjustable-frequency-square-wave-digital-display-signal-generator-module-stepper-motor-controller-p-10535.html
The module does work, sort of. Frequency specs are good for approximate use only.
