Author Topic: Easy Nixie Counter to Clock Modification  (Read 2288 times)
Offline @rtTopic starter
« on: June 12, 2017, 05:25:02 pm »
Hi Guys :)
I should really say “Without” any modification :)
« Last Edit: June 14, 2017, 04:28:31 am by @rt »
Offline Cliff Matthews
    • General Repair and Support
Re: Easy Nixie Counter to Clock Modification
« Reply #1 on: June 12, 2017, 10:08:40 pm »
Those 5's look about 100% better than the Rusky-tubes... Since it's only 12.5mhz, maybe the tube pin-out is compatible with the Elecrow PCB in this video:
« Reply #2 on: June 14, 2017, 04:59:54 am »
There’s still the question of why I can’t reset it by pulling the reset signal to ground with a microcontroller pin.
I assume the DC SSR could be streamlined down to a transistor or bilateral switch, but an IO pin of the micro set low should be ground potential.
