Author Topic: Glue Gun Hack - Adding a Power Switch & LED  (Read 676 times)
Offline made2hack
    • Made2Hack
« on: October 10, 2017, 08:12:48 am »
Offline Brumby
Re: Glue Gun Hack - Adding a Power Switch & LED
« Reply #1 on: October 10, 2017, 10:27:43 am »
A neat idea if you have a glue gun permanently plugged in.  I've never felt the need for a switch ... but, then, I don't use the glue gun all that often.
There is one part of your construction method that I would do differently - and that relates to your aerial soldering.  I would twist wires and leads together (as much as would be reasonable) before applying solder.  I would do this for most situations - but most certainly for mains wiring.  This not only provides some mechanical connection between the pieces, but it also allows for a larger bonding area for solder to flow through.  It is also quicker to solder, especially when you have 3 or more things you want to connect at the one point.
There is one reservation I have, though, and that relates to safety.  If the switch were to suffer a mechanical failure, then any exposed metalwork could become live.  I do realise that the element is contained within a metal body - but that will have been tested and compliant against the appropriate standard (assuming that the glue gun is an "approved" model).  This switch represents a defeat of the double insulation design that is typically used in these glue guns.  I would have preferred a switch with only plastic parts exposed to the operator.
Offline eugenenine
« Reply #2 on: October 10, 2017, 10:37:09 am »
I built a small version of Adam Savages glue gun setup
