I actually have two of those Gopher (Gophert) 3205E of which one is still functional. I thought I crack it open to see if it is as bad as the one I ripped apart.
It looked somewhat better but the PCB is of ridiculous low quality, it has started peeling and bulging just as the former one - How long does it take before this will fail just as the other one???
What is worse is the safety issue. The PCB is vulnerable and should be insulated from the casing, if a screw come lose or the copper peeling dips down you have mains voltage in the case. The only safety left is a rusty
iron tap. A very bad design, this tap has stresses to it and in the former tear down the soldering was cracked as well as rusty, it should have been implemented with a proper wire.
I realized a bit late the bad economy of buying cheapish noname crap ... After the first Gopher broke down, I gave up looking for the "perfect power supply", I.E. cheap, handy, reliable and decent quality.
I went off with a reputable brand, standard power supply (TTi EL302R) and I'm absolutely 100% convinced it is a fraction of the cost per hour used compared to the noname stuff
1) Gopher CPS-3205E;
$55 + VAT; died after two weeks
2) Gopher CPS-3205E;
$55 + VAT; lasts how long?
3) Thurlby Thandar Instruments, TTI EL302R;
$280; Has a track record of first class quality
Those two Gopher cost me more then half the TTi - a total waste of money
Do yourself a favor, go for a reputable brand from a reputable dealer, its cheaper even in a short perspective and definitely in the long term!
