Yup, exactly like that. Nomex is scarily expensive and so used for the very highest temperature classes only, you can get a 180 C rating with cheap, easy to find polyester insulation. You're looking for a creepage path of around 4mm on most common classes of transformers, so 2mm each side of the main insulating layers between the bobbin and winding for 2k5 V isolation (from memory). See standards documents for figures applicable to one's target usage (i.e. EN 90950 for computer and telecoms equipment).
