It was definitely about making an animation rather than writing a program, but go for your life
First thing I’d do is roll the circle drawing into loops, then create an array of the four rotating points,
and roll the propeller blades into a loop as well.
void transferToScreen() {
unsigned int lrow;
unsigned int lcol;
unsigned int lpixelvalue;
for (lrow = smlsizey-1; lrow > 0; lrow--) { // delete previous frame from bitmap
for (lcol = 0; lcol < FDATA_HEIGHT; lcol++) {
lpixelvalue = 0;firedata[lcol][lrow] = 0x00;
imgdata[bmpindex] = (lpixelvalue >> 16) & 0xFF;
imgdata[bmpindex+1] = (lpixelvalue >> 8) & 0xFF;
imgdata[bmpindex+2] = lpixelvalue & 0xFF;
bmpindex+=3;
// do propeller rotation
int increment = 6
rotation = rotation + increment;
if (rotation > (360-increment)) {rotation = 0;}
ox = 75; oy = 80; // propeller blade a
x = 75; y = 20; // 7
pixelrotation();
drawline(ox,oy,x,y);
lcol = xnew; lrow = ynew;
cx = xnew; cy = ynew; radius=5; drawcircle();
cx = xnew; cy = ynew; radius=4; drawcircle();
cx = xnew; cy = ynew; radius=3; drawcircle();
cx = xnew; cy = ynew; radius=2; drawcircle();
cx = xnew; cy = ynew; radius=1; drawcircle();
firedata[lcol][lrow] = 0x2F; // prop edge a
ox = 75; oy = 80; // propeller blade b
x = 75; y = 140;
pixelrotation();
firedata[lcol][lrow] = 0x3F; // prop edge b
ox = 75; oy = 80; // propeller blade c
x = 135; y = 80;
pixelrotation();
firedata[lcol][lrow] = 0x2F; // prop edge c
ox = 75; oy = 80; // propeller blade d
x = 15; y = 80;
pixelrotation();
firedata[lcol][lrow] = 0x3F; // prop edge d
lcol = ox; lrow = oy;
firedata[lcol][lrow] = 0x0F; // prop centre
if (cycledir == 0) {
pixcol++; pixcol++; // cycle colours
if (pixcol > 0xFD) {cycledir = 1;}
} else {
pixcol--; pixcol--;
if (pixcol < 0x2F) {cycledir = 0;}
} // cycledir
int doline = 0;
while (doline < 145) { // copy line to shutter effect buffer
lcol = shutterline; lrow = doline;
shutdata[lcol][lrow] = firedata[lcol][lrow];
doline++;
} // doline
shutterline--;
if (shutterline < 0) {shutterline = 159;} // move rolling shutter
if (shutenable == 719) {shutterline = 160;} // startup raster delay
if (shutenable > 720) {
doline = 0;
int shuttercnt = 159;
while(shuttercnt > shutterline) {
doline = 0;
while (doline < 145) { // write shutter effect buffer to screen
lcol = shuttercnt; lrow = doline;
firedata[lcol][lrow] = shutdata[lcol][lrow];
doline++;
} // doline
shuttercnt--;
} // shuttercnt
doline = 0;
while (doline < 285) { // moving indicator line
lcol = shutterline - 1; lrow = doline;
firedata[lcol][lrow] = 0xBE;
doline++;
} // doline
} // shutenable
shutenable++;
if (shutenable > 9999) {shutenable = 9999;}
bmpindex = 54;
for (lrow = smlsizey-1; lrow > 0; lrow--) { // write current frame to bitmap image
lpixelvalue = palette[firedata[lcol][lrow]];
bmpindex+=3;
