Thanks, I enjoyed watching that.
Those tiny CRT tubes you show at the end, are quite amazing.
I was very impressed with the build quality of the camera. Which is no real surprise, given that it is a professional, broadcast camera, and might be expected to take the odd knock, here and there, since it is portable.
I'm surprised that there was so much electronics, squeezed into that device. I guess it all has its purposes, and they wanted the picture quality, to be of the highest standard. Since it is not a mass consumer item, it would not be worth getting custom parts made up (except some things which were best made as custom parts, anyway, such as the switch labeling etc), such as custom ICs, as they would never get the development money back.
Which is probably part of the reason. But there may have been some custom parts.
Electronics was not that compact, then either, especially before surface mount technology and overuse of microcontrollers, further made things much, much smaller.
I could see a number of tiles in it. I wonder why it has got those ?
Maybe it is because they can have custom resistor values and maybe other stuff, built into it. Or could it be to save space, as it may be more compact, until surface mount technology comes out. It may even have surface mount parts on it, hence saving space.
The tiles could also be different, for different countries TV standards, if applicable. I'm not sure if that changes the camera, but the frame rates (50 Hz vs 60 Hz) may change.
