Author Topic: Cheapest 100MHz oscilloscope probes hands on review  (Read 56624 times)
Offline SpawnTopic starter
  • ³²µ º'ºººº³²
« on: March 10, 2012, 02:16:29 pm »
First off all this is just a review how these things look like and how they feel when you use them, unfortunately I can’t test the limits of these probes since I don’t have the equipment to do so.
I ordered these 5 days ago and received them today, because the probes I got are not good anymore, while I was trying to calibrate the 10x compensation, the little screw of the adjustable capacitor went weird so it doesn’t change anything if I turn it (common problem on cheap capacitors).
 I write this down because I was pretty impressed about the build quality of these cheap probes.
The probes are probably cheapest ones on Ebay, I ordered them from UK so they cost little bit more, but I didn’t want to get in trouble with customs here by ordering from China.
This is the set I ordered from Ebay, it includes 2x 100MHz probes from UK seller
Price including shipment: 15GBP, 23.5USD or 18EUR
http://www.ebay.com/itm/1pcs-100MHz-Oscilloscope-Scope-Clip-Probe-Measurement-Test-1x-10x-/330605425145?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item4cf99e71f9]This is the same probe from China seller but then the package contains one probe.[/url]
Price including shipment: 4.79GBP, 7.52USD or 5.75EUR
Probes feel really good in the hand and build quality is surprisingly good, specially compared to my 50MHz probe which cost me 15 times more long time ago.
Specifications:
Attenuation: X1 : X10
Input Resistance: 1Mohm ±2%(X1) : 10Mohm±2%(X10)
Input Capacitance:  1Mohm ±2%(X1) : 10Mohm±2%(X10)
System bandwidth:  DC~100MHz
Max input Voltage: X1: 300VDC+Peak AC   X10: 600VDC+Peak AC
Net Weight:  55g
Cable Length: 120cm / 42.2 inches
Package includes: 2x  Probes, 2x Probe tips , 2x Ground leads, 4x Marker rings, 2x Tip locating sleeves and a Adjustment tool
See below some comparing pictures with these cheap TP6000 probes, black 50MHz probes (don’t remember the brand) and Tektronix P6109 150MHz probes.
The package, I got 2 packs (4 probes)
The connectors, from above TP6000 probes, 50MHz probes and Tek P3109 probes:
10x compensation adjustment is on the connector and not on the probe itself:
The probes, TP6000 has a nice tip and good grip unlike the black 50MHz one. TP6000 is cheap but it doesn’t feel cheap when you have it in your hands, the black 50MHz feels and looks cheaper, I am not going to compare it with the Tek probe because its just unfair to compare 8USD probe to a probe which probably cost an arm and a leg to buy when they where new:
Ground lead, same order as before in above pictures, its slightly shorter than Tek lead, to be honest I like longer ground leads like the 50MHz ones even longer if possible, that just gives you more play room:
Tip compared to Tek tips, I don’t have the tip for 50MHz one anymore, but as you see the tip is exact copy of the Tek tips and they work quite same, it also fits on the Tek probes of course, so if you need a cheap hooking tip for your Tek probes these tips cost 8USD and you get free 100MHz probes as gift :P
I tested the probes (all 4 of them)  on my 20MHz iwatsu ss-5702’s  calibration output (0.3v 1kHz) just to see if they work, nothing further like testing with high or low frequency’s or different signal waves and voltages:
The following users thanked this post: trying to be clever
Offline T4P
  • Country: sg
    • T4P
Re: Cheapest 100MHz oscilloscope probes hands on review
« Reply #1 on: March 10, 2012, 03:51:16 pm »
Nice large CRO you have there , i'd better go down to my shop locally that sells second hand test gear to find a second hand large powerful CRO , probably heavy and would probably take up more space then i have now but oh well .
I have seen 1 probe on DX ( hongkong not china ) for 6.04$ and they have good ratings .
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: March 10, 2012, 04:33:29 pm »
Great photos and review.  I think I have similar models; I did some rise time measurements and they perform as expected.  They continue to perform well.
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/cheap-oscope-probe-quality/msg31749/#msg31749
Best Wishes,
 Saturation
  • ³²µ º'ºººº³²
« Reply #3 on: March 10, 2012, 06:26:43 pm »
Dave.S you would think it’s a huge oscilloscope specially on that picture, but it is one of the compact oscilloscopes in its time, you remember my newly bought Tek 2221A right?
This Iwatsu is only 6kg (13,2 pounds) and easier to carry around and Tek 2221A is 8.2kg (18 pounds) without its pouch on top of it ;)
I like my Iwatsu, the Volts/Div and Time/Div, buttons need some maintenance time to time and after that it works perfect again.
On topic again :)
Thanks saturation  and nice to see those tests, and good to know they perform well too.
The following users thanked this post: tpy
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: March 11, 2012, 10:43:22 am »
So it's compact longitudinal-ly ?  ;D
  • ³²µ º'ºººº³²
« Reply #5 on: March 11, 2012, 02:34:28 pm »
lol, yeap it was compact in those days now it’s more like a long toolbox.
For example on the front it is 43mm less wide than a Rigol DS1052E and 6mm higher, lengthwise it’s 3.5 times (287mm) longer than Rigol.
A quote from the manual first words:
The SS-5702 is a compact and lightweight oscilloscope which covers a frequency bandwidth from DC to 20 MHz.
Offline The Electrician
« Reply #6 on: March 22, 2012, 07:41:34 am »
I also bought some of these Chinese probes for around US$12 on eBay.  They are better than you would think.  The are advertised as being 100 MHz probes, but they are much better than that.
To test them, I used a Tektronix tunnel diode pulser which outputs a 125 picosecond rise time pulse into a 50 ohm load.  My fastest scope is an Agilent DSO5034A, 300 MHz bandwidth.
I connected the pulser through a 50 ohm feedthrough to the 1 megohm input of channel 1 of the scope and captured the rise of the pulser.  The result is in the first image.
I then set the scope input impedance to 50 ohms and fed the pulser directly into that input.  This result is shown in the second image.
« Reply #7 on: March 22, 2012, 07:46:12 am »
Next I connected one of the probes, labeled PP-150 near the BNC connector, to the output of the pulser, with the probe set to 10x and with the ground lead connected to the ground of the pulser.  The ground lead was positioned to occupy a nearly circular loop.  The first attached image shows the result of this setup.  You can see substantial overshoot and ringing.
Then I wrapped the ground lead around the probe tip, to minimize the loop area of the ground lead.  This result is shown in the second image.
« Reply #8 on: March 22, 2012, 08:05:17 am »
For these tests, I disconnected the ground lead and connected the probe tip with the included spring adapter directly to the output of the tunnel diode pulser.  This shows the fundamental response of the probe.  The first image is taken with the PP-150 (manufacturer name unknown) probe.  This probe has enough overshoot to make the rise time measure less than 1 nS.
The second image shows the performance of the Aidetek P6100 probe.  It has less overshoot than the PP-150.
The overshoot these probes exhibit is due to the extremely fast 125 pS rise time from the tunnel diode pulser.  If a rising edge with more than several nS rise time is applied, you don't see overshoot (without the ground lead, of course.  With the ground lead in use you will get overshoot and ringing even with nanosecond rise times).
« Last Edit: March 22, 2012, 08:26:44 am by The Electrician »
« Reply #9 on: March 22, 2012, 08:17:07 am »
I also bought two 100:1 probes for US$70 on eBay; they are rated 250 MHz.  The first attached image shows the rise time of one of these probes driven by the tunnel diode pulser.  The output of the pulser isn't large to start with, and by the time it's attenuated 100 times, the signal is weak.  But we can still see that the rise time is 2.2 nS.
The second image here shows the performance of the Agilent 10073C probe, rated as a 500 MHz probe.  The rising edge with this probe is very clean, with almost no overshoot.
The two Chinese probes are much better than their rated 100 MHz; I would call them 200 or maybe even 300 MHz probes.
alm
  • Guest
« Reply #10 on: March 22, 2012, 08:20:45 am »
What's the loading at 200/300 MHz for these supposedly 200/300 MHz probes? How do they perform when driven frome a higher source impedance?
« Reply #11 on: March 22, 2012, 09:47:49 am »
The specification says the input capacitance is 18.5pF to 22.5pF, which is quite similar to Tektronix and Agilent probes.
But, it occurred to me that I might be able to get a better answer to your question.
I set up a network analyzer to sweep 100 kHz to 300 MHz and display impedance on a Smith chart.  The probe was connected to the input of the scope and the probe tip was poked into the center conductor of the network analyzer's connector; I used a piece of braid to connect the shell of the analyzer connector to the ground of the probe tip.
In the attached image, the white curve is for the Chinese probe and the yellow curve is the Agilent 10073C probe.
The following users thanked this post: trying to be clever, 5U4GB
Offline saturation
    • NIST
« Reply #12 on: March 22, 2012, 08:03:20 pm »
Thanks the electrician,  these are the best tests I've seen on eevblog for probe performance!
I recently obtained a Tek 284 generator that uses a tunnel diode to generate ~70ps pulses [ which I can't confirm is so at this point...] for doing higher speed tests in anticipation of a better scope in the future, currently I just have a Rigol 1052e.
The fastest Chinese non-name passive probes I've found are 500 MHz, they are about $70-85 each, delivered, but at those prices I'm skeptical about no-name performance.  I've found that for the same money, Picoscope's TA069 look like the no-name 500 MHz one [ and the same accessories!], but I hope Picoscope does quality control on them.   One problem with no-names and Chinese label, is quality control: one can't be sure if buying another of the same brand or a no-name if the >= performance can be expected.
Preliminary tests on TA069 vs no-name 100 MHz Chinese label and the Rigol 200 MHz P2200 probes, provides qualitatively cleaner looking pulses but rise times are all rate limited by the Rigol.  Screen shots to follow later.
http://www.ebay.com/itm/500MHZ-Oscilloscope-Probe-Hp-Tektronix-/320841226231?pt=LH_DefaultDomain_0&hash=item4ab3a097f7
http://www.pc-oscilloscopes.com/product_info.php/cPath/40_45/products_id/569
TA069
'Texas' labeled 500 MHz Chinese probes:
« Last Edit: March 22, 2012, 08:05:16 pm by saturation »
Best Wishes,
 Saturation
« Reply #13 on: March 25, 2012, 10:27:22 am »
You notice that the rise time of my 300 MHz scope was 1 nS when the tunnel diode pulser was connected directly to the scope.  The rise time through the Chinese probes was also essentially 1 nS, so I would need a faster scope to truly measure the probe rise time, which must be better than 1 nS.
For a price of 10 to 15 dollars, these probes are amazingly good.  The build quality is good and I keep the Agilent 10073C probes put away and just use the Chinese probes for everyday use.
I notice the 500 MHz probes you mention have an input capacitance of 11 pF; not much better than the probes I tested, and a lot more money.  If a person really wants to probe very fast rising edges on a node of relatively high impedance with minimal loading, I think you would have to use an expensive active probe.
alm
  • Guest
« Reply #14 on: March 25, 2012, 12:07:06 pm »
300-500 MHz bandwidth Agilent/Tek probes would have something like 8-12 pF of input impedance, or about half of the HF loading.
How accurate would a network analyzer be for this measurement, given that the impedance is very far from 50 ohm?
Rise time doesn't tell the whole story, however. The cheap probes showed substantial overshoot, much more than with the direct connection or Agilent probe, indicating an over-peaked response. This results in a higher apparent bandwidth, at the cost of transient response (accuracy at and shortly after the rising edge). A CW sweep of the probe across the scope's bandwidth might show a dip in the frequency response somewhere far below 300 MHz.
I would expect the performance with a fast high-amplitude signal to be substantially worse than the Agilent probe, since capacitors and resistors in the attenuation network will likely have some voltage coefficient.
I can see why you'd rather kill a $10 probe than a $200 probe, but I would still keep some good probes around for when accuracy matters or you don't trust the cheapies for some reason. My experiences with durability of the cheap probes and their accessories (eg. Rigol) aren't too good, but I guess for $10-15 you don't care.
« Reply #15 on: March 25, 2012, 06:08:49 pm »
I measured the 500 MHz Agilent 10073C at low frequencies and its input capacitance is 12.55pF compared to their spec of 12 pF.  The Chinese probe measured about 16 pF, better than their spec.  However, at high frequencies, transmission line effects begin to dominate.  At 300 MHz the impedance of the 10073C 500 MHz probe is 42+j74 which works out to about 5 pF in parallel with 176 ohms.
I have destroyed one probe over the course of 2 years, and I made some measurements on the cable.  The center conductor is very fine resistance wire, with a DC resistance of about 230 ohms end to end.
Perhaps you are speaking of the 100 kHz impedance of .01 + j7667 ohms, on the far right edge of the Smith chart.  In the 100s of megahertz range, the trace is in the region of the Smith chart where the impedances are on the order of 100s of ohms and the accuracy is quite good.
The direct connection to the scope through a 50 ohm feedthrough and the scope set for 1 M ohm input impedance showed some overshoot; I don't know if the scope exhibits some overshoot or if the tunnel diode pulser has some. The P6100 probe showed somewhat less overshoot than that.  The Agilent 10073C probe showed almost no overshoot but the direct connection to the scope did show overshoot; what do we make of that?  At rise times in the nanosecond range, rather than 125 pS, the Chinese probes don't exhibit overshoot.
I performed sweeps a while ago; I'll post those.
The capacitors are low pF caps, and there would be no need to use high-K dielectrics which exhibit a large voltage coefficient.  The caps are most likely NPO which has a negligible voltage coefficient.  I would also expect the resistors to have negligible voltage coefficient.  I don't think that "...some voltage coefficient" necessarily translates into "...performance with a fast high-amplitude signal to be substantially worse..."
At any rate, the largest very fast rise pulse I have available to me is a 900 pS 5 volt pulse from a 74AC series logic buffer, and I didn't see any worsening of performance.  For a somewhat slower rise, say 3 or 4 nanoseconds, I can generate a 100 volt pulse, and I didn't see any worsening of performance there either.
I broke one of the Chinese probes after about 2 years of use by accidentally yanking it, which is the same thing that has killed the expensive probes in the past.  I'm quite satisfied with the Chinese probes.
Attached are images of the swept frequency response of the DSO5034 scope, the Chinese probes and the Agilent 10073C 500 MHz probe.  The probe sweeps were displayed on the DSO5034 scope, so take the rolloff of the scope into account when considering the probe sweeps.
The sweeps are 100 MHz per division, terminating at about 760 MHz.  The vertical scaling is linear, of course, not logarithmic.  The scope's response is quite flat to 300 MHz and rolls off gently after that.  You can see that the P6100 probe is much flatter than the PP-150 probe.
« Reply #16 on: March 25, 2012, 06:21:57 pm »
Just for grins I connected the cable from the damaged Chinese probe to the network analyzer and shorted the end.  The result is shown in the attached image.  The marker is at 100 kHz and you can see that the impedance at that frequency is about 230 ohms real with a small capacitive part.
As the frequency is swept up to 300 MHz, the impedance follows a spiral toward the characteristic impedance which is in the center of the spiral, something like 150 ohms or so, with a substantial capacitive part.
The center conductor of this cable is a very small resistance wire, and the cable is very lossy.
alm
  • Guest
« Reply #17 on: March 25, 2012, 08:52:17 pm »
I would tend to believe the direct 50 ohm connection, since 50 ohm inputs tend to be superior to high-Z inputs. I would also expect the pulser to be happier since the load is much more resistive. On the other hand, it's quite common for probes to compensate for imperfections in the scope's input impedance and response. This is why companies used to make several different probes with the same bandwidth. Nowadays they tend to use the same front-end for most of their scopes, reducing the number of different probes they need to make.
The big scope vendors like Agilent (HP) and Tektronix used to spend a lot of time and effort to reduce voltage and frequency-dependent effects in the attenuation hybrid. I'm not sure if this technology is within reach for an Asian manufacturer that makes $15 probes, maybe it is.
Thanks for posting these. Do you expect the setup to cause any significant errors? Eg. reflections from the not very well terminated transmission line?
It looks like the DSO5034 + 10073C does not meet specs, the -3 dB point appears to be about 250 MHz to me. Is this combination recommended by Agilent? The PP-150 response looks quite horrible to me, with the response up +3dB from 100 MHz to 200 MHz. The P6100 looks quite good, however. This is consistent with the step response measurements.
I'm surprised that these probes exceed the specs by so much, especially switchable (1x/10x) probes. For the price, I wouldn't even expect them to meet their specs. Would the quality control be insufficient to meet this performance consistently, or would there be some other issue that we're missing?
When searching eBay for P6100 I find the probe under various brands: Yang Xun, no brand at all, Caltek. Any idea if they're all made by the same manufacturer and relabeled or if P6100 is the generic name for scope probe in China?
Neat! Not sure what to conclude from this, however, pretty much what you would expect from a lossy transmission line I guess.
« Reply #18 on: March 25, 2012, 10:38:40 pm »
The pulser saw 50 ohms in both cases.  When the scope was set for 1M input, the pulser was connected to the scope through a 50 ohm feedthrough, the sort you use to terminate the older Tektronix current probes.
The pulser is in a small metal box, and no cable was used to connect it directly to the scope; this is the pulser:
http://www.ebay.com/itm/Tektronix-067-0681-01-Tunnel-Diode-Pulser-calibration-fixture-/110847494323?pt=LH_DefaultDomain_0&hash=item19cf0688b3
I think reducing the voltage dependencies due to voltage coefficient in a small NPO trimmer can't be too hard.  Frequency dependencies are another matter.  Since Tektronix did the work a long time ago, all the Chinese manufacturer has to is copy.
Anyway, the measurements I've been able to make show that for rise times I care about (not 125 pS, 100 volt excursions), a few nanoseconds, I don't see any noticeable performance degradations that I would attribute to voltage coefficient problems.  When I compensate the probe for a pulse amplitude of 1 volt, and then apply a 100 volt pulse, I don't see any changes in the displayed pulse edge shape.
The probes were connected to the scope with the scope input set to 1M ohm.  The probe tips were poked into the center conductor of the type N connector which was the sweep generator output, with a piece of braid wrapped around the probe tip ground collar and the shell of the type N connector to provide reasonable continuity there.  Whatever errors there may have been, due to reflections in the probe cable were what one would have to tolerate if one were probing such high frequencies without maintaining a 50 ohm environment, but rather using a 10x probe.
The 10073C is the probe provided with the DSO5034 and also the 500 MHz DSO5054.  I was puzzled by the less than expected frequency response.  The probe is spec'd to have a 700 pS rise time, but I can't verify that.  It certainly does well at 1 nS, and has a nice gentle rolloff in frequency response.
I can't explain it, but when I discovered their performance, I was also surprised.  Even if they only last a year, at that price they're great for everyday work, allowing one to preserve the expensive probes that came with the scope for special occasions.
I can't answer that, but given the ability of the forum readership to discover things like that, I expect someone to let us know.
The thing the network analyzer curves show is that the input capacitance specified by the manufacturer is a (relatively) low frequency spec.  At high frequencies, the input capacitance is determined by the cable; the compensation trimmer and scope input capacitance are decoupled from the probe tip by the properties of the cable, which is several wavelengths long at 100s of megahertz.
At the time I did those sweeps, I also did a sweep of the response of a Rigol DS1204B, a 200 MHz scope.  I've attached the image.  Notice that it doesn't have the gentle rolloff a good scope should have.
Rohde & Schwarz have a new scope out, and I've been seeing advertisements touting their Gaussian rolloff, giving good pulse fidelity.
alm
  • Guest
« Reply #19 on: March 25, 2012, 10:59:36 pm »
In one case it saw a resistive 50 ohm, in the other case 50 ohm // 10-20 pF. The capacitance becomes quite significant at the frequencies generated by a 125 ps rising edge.
I was thinking of standing waves in the cable to the probe (not much of a cable it seems), or the leveling circuit of the generator being influenced by the reactive load/reflections it sees. I know this is a problem in (fast) scope bandwidth testing, and the reason why they use as many attenuators as possible between the generator and the scope. Even those '50 ohm' input scopes often don't have great VSWR specs.
Funny. Agilent published an appnote about the superiority of the brick wall response for pulse measurements a number of years ago ;). I believe their argument was that the superior pulse fidelity of the Gaussian roll-off is only relevant if the pulse is faster than the scope, and you should just buy a faster scope if that's the case.
« Reply #20 on: March 26, 2012, 04:11:02 am »
In your very next comment, you say "Even those '50 ohm' input scopes often don't have great VSWR specs.", so we don't know to what degree "...it saw a resistive 50 ohm".  I won't be back home for a few days, but when I get back I will connect the 50 ohm input of the scope to the network analyzer and see just how good a 50 ohm load it is.  For all we know even the 50 ohm input may look significantly capacitive to a 125 pS edge.
Knowing that a passive 10x scope probe is not going to be well matched to a 50 ohm environment, I wanted to do the best I could but in a way that would be typical of how an ordinary user might (mis)use the probe, so I connected the probe tip directly to the generator output connector with no intervening cable.  I don't see the sort of undesirable behaviors I would expect to see if there were substantial reflections, or a leveling circuit failing to do its job.  The scope cable is so lossy that any reflections will be greatly attenuated.
At any rate, since a 10x scope probe is not a controlled impedance cable, how else can we measure its "frequency response"?
Superior in what way?
alm
  • Guest
« Reply #21 on: March 26, 2012, 09:10:50 pm »
Neither is perfect, but I expect the scope input to be significantly better, unless the designers were really lazy and just switched a 50 ohm resistor across the input. Hard data trumps any assumptions, however.
Fair enough, I'm just trying to exclude any potential source of uncertainty. The usual method would be to terminate the 50 ohm connection as close to the probe tip as possible, to minimize the sub length, but you're probably already quite close to this.
Rise time measurements. This is the appnote I was referring to.
Offline Gerry Powell
« Reply #22 on: March 01, 2016, 04:32:48 pm »
I'm in need of some ground clips for Tektronix probes P6105. On ebay, there are some inexpensive ones from China, does anyone know if they will snap into the Tek probes?
http://www.ebay.com/itm/5pcs-New-Oscilloscope-Scope-Probe-Ground-Leads-with-Alligator-Clip-Tektronix-HP-/350774225173?hash=item51abc5e915:g:3IUAAMXQTZhR1QuB
Gerry
« Last Edit: March 01, 2016, 04:34:52 pm by Gerry Powell »
Offline Martini
« Reply #23 on: April 16, 2016, 12:33:40 pm »
I bought one of these (P6100). The manual mentions a ground spring, I don't have one. Did yours get with it?
