Going through of pile of stuff I've wanted to take apart for a while, so here is another one located at
http://kuzyatech.com/innolux-bt156gw01-tft-lcd-panel-teardownThis is a panel used in many laptops, including Dells. I've not been able to locate datasheets for some of the chips used, so hoping somebody can weigh in on a few things:
What does the main LVDS chip do on this thing? I see 4 LVDS lanes coming in and 7 coming out. They seem to be separating clock and video data and then sending that to the six individual driver chips mounted on the flex cables. Do they do some processing there as well?
The other question is why do they leave extended data EEPROM power pin connected to the main connector instead of powering locally?
And finally, I've counted 6 separate optical films behind the display (and none in front)
Some are pretty obvious, like the rear reflector and backlight sheet. But then I see two diffuser like sheets and two Fresnel-like or prismatic sheets. What do they do?
