For me, the Metrahit Energy has been a very good user experience, unlike my previous Fluke 89IV, which has quite a few hardware problems, like progressively more flaky rotary switch (I'm trying to send it to Fluke and see if I can get it fixed for free) and high battery consumption. The key feature for me, and the reason why I got Metrahit Energy is the power/energy measurement function. Last time I checked, there is no equivalent Fluke meter available in that respect, other than way more expensive power quality analyzer.
I'm currently checking thermostat temperature settings of our refrigerators with a Pt100 RTD and logging function to minimize the energy consumption with few iterations. I have already found one flaky thermostat (too cold) which needs fixing. I think Fluke does not support temperature readings via Pt100/1000. One could always use a thermocouple, but still. RTD wires are easier to extend ad-hoc and one can enter the lead resistance to remove the error related to that. The possibility to use an AC-adaptor is a big bonus if one does much long-period logging to avoid eating truckloads of batteries. And a positive surprise for me, is that I'm still using my first set of batteries (those which delivered with MetraHit Energy), unlike Fluke which has eaten truckload of them in the meantime.
I'm personally not so worried about software issues, since they will get eventually fixed, if the manufacturer is respectable, something I expect Gossen to be. I don't blame them if they manage to fail sometimes, I expect them to sort it out with no fuss no muss. For hardware/mechanical faults, things are always more difficult. For me, the acceptable solution would be a command or a tool which could be used to make a reliable backup of all the calibration factors, and if any problem occurs in the upgrade process, then I could restore them from the backup. Of course, delicate operations like firmware upgrade should be initially made as bullet-proof as possible.
Regards,
Janne
