Hello, recently I added to my collection a beautiful solartron 7061 multimeter.
The meter seem to function correctly but the low price I paid is justified by some problems.
The problems are that the unit seem to be far off calibration, some of the measurements it
shows are wrong by half a percent.
I turned the calibration key and entered the cal menu and soon the unit started showing the
"cal not done" message, i returned in normal position without proceeding into calibration routine.
Now it shows "cal not done" after startup and "CALO" text aside the measurement.
Is there anybody that knows this instrument?
I have operating manual that includes cal procedure but it would be nice if somebody has or
can tell where to find a service manual.
It has a 3.6V nicd battery that is dead, i desoldered it and cleaned the area that started
corroding, i read somewhere that the ram powered by this memory contains only power
clock and measurement data.
There is also a seeq DQ2816a EEPROM that I suspect contains cal costants.
I tried to start the meter without the EEPROM ant it's behaviour is the same than
with it, so I suspect the 2816 is failed and this justifies the scrapping of the meter
by the original owner.
I think it's time to for me search for a cheap all-round eprom programmer, any
suggestion is welcome
Fabio.
Following the photos that show the instrument, the memories, the battery,
the reference area and some canned components marked vishay 0.01%
that should be resistors.
The reference is built around a 1N829 zener diode, I didn't expect a
"simple" zener as reference for such a resolution but I think the knew what they
done.
