I don't have a metrology lab, so for temp, you get what you get. These tests were run between 60 and 61F. To really get a voltage standard to consistently run to the 0.1 mV benchmark, one really needs a feedback mechanism to handle temperature compensation.
I'll put up a simple schematic later. The 3.3K resistor was placed in line with the zener reference. I put a 1Mohm in front of the DMM measuring the source voltage to try and reduce the loading on the reading. Is that "correct"? Probably not, but its what one has to do without any feedback compensation. It's a dance between keeping enough current flowing through the zener to get it past the knee, not heat it or the resistor significantly, and keep it at as close to one current as possible. See attached diagram. The IV curve to the left of the knee looks like a cliff, but its not. Once you're in the uV neighborhood, the slope of that line matters.
This is pretty much all I have time for at this time. I actually need to get back on track on another project.
on't have a metrology lab. These tests were run between 60 and 61F. To really get a voltage standard to consistently run to the 0.1 mV benchmark, one really needs a feedback mechanism to handle temperature compensation.
Good luck with your project!!
