Author Topic: [Bathroom TV hack] TFT Monitor PSU capacity - adding ARM board as media player  (Read 1017 times)
Offline faekjarzTopic starter
  • I'm half cat, half platypus, and half pink! :3
Hey there, Enginerds and DIY afficionados!
I really like watching videos while enjoying a hot tub in my bathroom. I happen to have an old Samsung 940NW (click "SEE FULL SPECS") TFT Monitor which i'd like to convert into a VESA wall mounted media playback appliance according to the following spec:
  • some low power ARM board, what for running the operating system
  • "SJW/Linux" ;) OS with X GUI for VLC, MPV or Kodi on a low-spec desktop env like openbox or xfce
  • capable of 720p60 playback, preferably 1080p30 minimum (up/downscaled to [1440x]900p, the native TFT res)
  • ARM board has VGA output (i haven't researched the TFT input board yet, for now that's the only available input)
  • maybe use of a (bus-powered) external HDMI-to-VGA converter
  • wireless LAN, what for mounting my main rig's storage via sshfs …onboard or external via USB dongle?
  • tiny USB keyboard, maybe touch panel and on-screen-keyboard, capacitive, none of that resistive rubbish
  • all powered via the original TFT monitor PSU ...preferably
  • i might even tap the mains supply and add a secondary PSU for that ARM board ...just in case the TFT PSU isn't strong enough
  • boot from USB or SD card
  • i'm not afraid of crimping / soldering stuff
  • i'd even replace the TFT / LVDS input board to accommodate a non-VGA ARM board video output
  • ...composite to VGA converter? (least favourite option / last resort)
Experiences / comments?
  • I'm sure a RaspberryPi is one of the first recommendations, thank you …what else?
  • Is it feasible / could the PSU have sufficient reserves to power an additional ARM board?
  • Which in-spec low-power ARM board would you recommend?
  • Links to existing projects / logs?
  • Maybe a furious rant about my utter stupidity, followed by a tremendous spillage of enlightened wisdom …LOLMUHARHARHAHAHAROFLMAO ;D
…the project progress (my decisions) will be logged in this thread (with photos and explanations).
