Author Topic: [First post] Fake x2 capacitors?  (Read 15606 times)
Offline james_s
Re: [First post] Fake x2 capacitors?
« Reply #25 on: April 21, 2017, 05:14:37 pm »
Yeah I'd like to make it clear that when I complain about "Chinese sellers" I'm not complaining about the general population of China, nor am I implying that everyone in China selling stuff on ebay is a scammer, but there are a LOT of scammers selling junk on ebay so the problem is that you don't really know, and it seems the Chinese government is either unwilling or unable to do much about it. I suppose it's a natural consequence of having a red hot market, massive quantities of surplus components, and large numbers of people trying to scrape by and make ends meet one way or another, with a huge pool of buyers way off in a distant land so there is no direct interaction, one can't inspect the goods prior to purchase, and returning defective goods is not cost effective. It's an environment that is ripe for scams.
Now as for buying parts on ebay, some of it is good, some of it is junk, if you know what you're getting or don't mind taking a risk then there are some deals to be found, but buyer beware. There are things I'll buy from unknown offshore sellers and there are things I won't. Safety components like X2 capacitors and high voltage fuses are one of those things I won't. It's just not worth the risk.
Offline Siwastaja
« Reply #26 on: April 21, 2017, 05:23:04 pm »
Probability theory excercise: Buy 20 components for a project. At 30% fault rate for each component, what is the probability that at least one in the project is faulty? If you spend, on average, 10 hours of debugging caused by each faulty component, how many hours (expected value) are you going to spend on this 20-component project?
My experience on my own projects as well as debugging a lot of others' projects is that while it often works to buy an Arduino board, an LED and a resistor from Ebay to blink the LED, when the project gets any more complex than that, the chances that at least one vital component is broken in a funny way asymptotically reaches 100%. For example, it takes some debugging to find out why a 3V3 regulator is giving out 1V8. As a beginner, you always doubt your own work, which is correct because, when using genuine components, you are the source of 99.9% of the problems. But when you mix in a bagfull of faulty components you need to debug and swap, working for hours and hours on them just to find that they were faulty to begin with, then order some more, wait for a week to get the new parts - which again may be broken - you are creating an environment where you'll never get your project finished until you lose all your motivation.
Another issue is that you typically cannot source all of the components needed in a project from Ebay, so you "need" to buy from a proper distributor anyway.
Ebay is great for sourcing some trivial parts that for some weird reason are missing from the distributors, are hard to find, or are prohibitively expensive for what they are. For example, I have bought several $1 flux pens when FARNELL was, at the time, only selling flux pens for $100/ea(!).
« Last Edit: April 21, 2017, 05:28:44 pm by Siwastaja »
Offline wraper
  • Country: lv
« Reply #27 on: April 21, 2017, 05:47:45 pm »
I guess you are talking about Bonkote Bonpen. First of all, they are not $100 each but $100 for a pack of 5 which is standard packaging. But you can find places which will open the pack and sell them individually. Secondly those sold on ebay for cheap are all crappy counterfeits, are not ESD safe and don't perform anywhere nearly as well as genuine stuff (tried that crap for comparison).
Offline Seekonk
« Reply #28 on: April 21, 2017, 05:49:14 pm »
I don't really think of X2 caps as "safety" application. If something is line powered there is always a potential for things to short hence the need for some interruption.  If you buy a polyester X2 cap, then whats the point. After common mode inductors they often go to standard capacitors.  And there are no standard capacitors, they are all designed for particular applications.  X2 caps are at least some implication that they are designed to operate without corona degradation.   I've designed many 480V line powered devices with capacitive dropping and brought them through UL without X2 caps. The caps were designed to withstand AC.  Unfortunately most data sheets for capacitors are including less and less information.  Hard to figure out what the limits of some capacitors are. If you buy a lot of capacitors you get access to engineering dept and they will even design capacitors for you. I've always found these calls fascinating.
Offline RukyConTopic starter
« Reply #29 on: April 21, 2017, 05:55:58 pm »
I do test the parts before soldering the onto the board.
I even test the parts i get from mouser and digi-key.
The following users thanked this post: splin
Offline Siwastaja
« Reply #30 on: April 21, 2017, 06:03:05 pm »
The issue is not within completely nonfunctional parts, they are easiest to identify.
Parts that are "tested OK", but misbehave or have reliability issues can end up being horrible wastes of time, and hard to debug in actual full circuit. And these are surprisingly common.
Proper testing takes a lot of time and equiptment, too, if you try to characterize the components.
Offline Siwastaja
« Reply #31 on: April 21, 2017, 06:07:32 pm »
Flux pens I have bought from Ebay for $1 are certainly not counterfeits since they don't claim any other brand than their own, thus, they are genuine. They don't even try to look like the Bonpens, or any other brand name thing. Indeed, I'm sure these are not ESD safe, but these do work fairly well.
Sometimes, getting a workable but lower quality option for 1/100th the price of the good alternative is a good choice. This principle doesn't, however, work with most Ebay components, since they are usually priced at near distributor prices, and the parts can cause countless hours of debugging, something that cannot be described simply as "lower quality".
« Last Edit: April 21, 2017, 06:11:13 pm by Siwastaja »
Offline wraper
  • Country: lv
« Reply #32 on: April 21, 2017, 06:13:43 pm »
well, basically if you search for flux pen on ebay, basically there are 2 things. Fake bonpens and other type which is like marker. Those are much worse than a brush. And similar (but much better quality) flux pens don't cost nearly as much as bonpen even at digikey.
« Reply #33 on: April 21, 2017, 06:34:09 pm »
Now if i'm going to use them for something like a capacitor dropper supply, wouldn't be easier to diagnose the problem?
Offline james_s
« Reply #34 on: April 21, 2017, 06:35:01 pm »
X2 capacitors are classified as safety devices, they may be connected directly across the line. If they fail, they must fail gracefully and not catch fire or sit there and smolder. If you want to take the risk, I'm not going to stop you, but I don't think I personally would.
Offline Siwastaja
« Reply #35 on: April 21, 2017, 06:35:50 pm »
... if you can find them. In that case, Farnell couldn't deliver any flux pen under $100, and Farnell was our preferred distributor.
It's very well possible that Farnell had the actual flux pens I was looking for miscategorized or mislabeled. This frequently happens with them. I could have called their support phone. It's a hassle.
Nowadays, due to too many utter fails, I tend to refuse to use Farnell and prefer Digikey instead mostly due to their usable website.
Anyways, my point was that sometimes due to some really silly reason it is impossible to get trivial things from the distributors. Often it's a catalogue mistake, leading to spending a full working hour just to find the part number for a trivial low-cost plastic or metal part. These working hours do have a cost. Inability to get a flux pen under $100 at a certain time was a personal example, maybe not the best possible.
Offline Siwastaja
« Reply #36 on: April 21, 2017, 06:37:57 pm »
Yeah, in a capacitor dropper it's more about the chances of it catching fire later on, than debugging some issue initially.
« Reply #37 on: April 21, 2017, 06:44:10 pm »
Can a fuse possibly reduce the chance of that happening?
Offline Siwastaja
« Reply #38 on: April 21, 2017, 06:47:46 pm »
Of course it can, but it's not a silver bullet.
Any component not becoming a "full" short, but a resistance instead, can itself become a heater element causing excessive heat, leading to fire. But the fault current might not be enough to trip the fuse. This is a known failure mode with capacitors. The very idea of the X2 capacitor is that it's designed so that this is extremely unlikely.
Offline james_s
« Reply #39 on: April 21, 2017, 06:53:04 pm »
A fuse is certainly a good idea though, regardless what capacitor you use. Something rated high enough for the voltage, with a current as low as it can be without risking false trips.
« Reply #40 on: April 21, 2017, 06:58:07 pm »
That's why i said reduce, not prevent.
Now, which would you trust more, eBay x2 caps or salvage x2 caps. [EDIT: Forgot the L in salvage so i put it in. :-[ ]
« Last Edit: April 21, 2017, 07:17:09 pm by RukyCon »
Offline james_s
« Reply #41 on: April 21, 2017, 07:11:24 pm »
Savage? Did you mean salvage?
Personally I would trust salvage more, assuming they are in good condition and came from reputable equipment.
« Reply #42 on: April 21, 2017, 07:15:10 pm »
Yes, i did mean salvage, My bad.
Offline Fungus
« Reply #43 on: April 22, 2017, 12:43:04 pm »
But this is something we should and can evaluate based on facts, not feelings. The ratio of bad stuff sold by Chinese Ebay sellers is just huge.
Yes, but the price of buying "good" stuff is sometimes so high that it's often worth buying two or three lots from different sellers and crossing your fingers.
eg. Here in Spain any order from Farnell et. al. carries a minimum 15 bucks shipping cost.
Stuff like MOSFETs and voltage regulators are almost all rejects/fakes (apparently) but even so it's only a real problem if you're selling them to people or planning to use them at high power ratings. For home/hobby use or powering a toy from a 9V battery you'll be fine with an eBay regulator.
Offline wraper
  • Country: lv
« Reply #44 on: April 22, 2017, 12:53:40 pm »
Really, your own blown stuff and wasted time does not count? You could buy known genuine MOSFETs with 3-5x lower current rating and, likely, they still will be better than ebay/ali special. From my own experience, even if you get genuine stuff, very likely around 10% will be faulty, be it rejects, ESD or whatever caused them be faulty. For example I've got a batch of attiny24A with around 8% of them having faulty flash.
If the price difference is so high that it "makes sense" to buy 3x amount of the parts, most likely, none of those batches will be genuine.
« Last Edit: April 22, 2017, 01:12:10 pm by wraper »
Offline wraper
  • Country: lv
« Reply #45 on: April 22, 2017, 01:03:11 pm »
Or there was shortage of one pretty unique but cheap IC at all major distributors for a few months, had no choice but to order from aliexpress. I'm pretty sure does it not have clones. Form 250 pieces in a tape, in total around 20% were faulty. And the strangest fact was that most of the faulty ones were at the one end of the tape, being around whopping 80% faulty at one end and mostly working on another. Of course nobody bothered to properly package them as well. Guess they received some huge ESD impact at some point of time. Paid for them as much as farnell asks, so it's not like it was some known crap.
EDIT: The not so fun fact was that I tested a few from that "good end" of the tape and found them fine. Under he microscope they were 100% the same as those from Farnell, package, top and bottom markings. In the end had to do hell a lot of reworking the boards.
« Last Edit: April 22, 2017, 08:22:54 pm by wraper »
Offline Fungus
« Reply #46 on: April 22, 2017, 06:23:53 pm »
What if i only plan on using them on custom projects? [Like small LED lights]
Not a problem. Buy thousands, with confidence.
Offline Seekonk
« Reply #47 on: April 22, 2017, 07:49:08 pm »
An owner asked me to submit the paperwork for a legacy product to get CE. It was a application that clearly required X2 caps, the paperwork even asked for the certification. He told me to leave it blank.  He was going to travel to the country, take them out to dinner and negotiate the acceptance.  They ended the test early when almost all the samples failed.  $40K down the tubes.
Putting two caps in series is a pretty good substitute for X2 caps. This is their construction internally to reduce corona degradation.
« Reply #48 on: April 27, 2017, 11:48:17 am »
By the way it looks, it looks like most people say no to x2 caps from eBay.
Offline macboy
« Reply #49 on: April 27, 2017, 01:02:53 pm »
You don't need X2 caps in a dropper because in that application the cap is not directly across the line, it is in series with the load, which is entirely different. I have seen many commercial products, all listed, all with non-X2 caps in their dropper circuits.
"Pretty good" isn't good enough. There is no acceptable substitute to X2 rated caps. If you need them, then you need them. The rating/certitification counts in addition to the performance.
