Author Topic: [HELP] HDMI 2.0 to MIPI-DSI / LVDS [SOLVED]  (Read 66428 times)
Offline Kilrah
Re: [HELP] HDMI 2.0 to MIPI-DSI / LVDS [SOLVED]
« Reply #25 on: May 10, 2016, 09:49:13 am »
That's the main problem, none of these boards can just take an HDMI/DP/whatrever input and convert it, so you can't have a "real" projector that is simply a "passive" display device you can connect anything to.
Everything will have to be played by/processed on the board.
One thing I'm dubious of and that was never talked of but is nearly more important is the quality of the optics. I doubt anything you can easily obtain is worth sending a 4K picture through. Not much worth the trouble to create a 4K display part and end with a muddy projected image full of distorsion and chromatic aberration.
The following users thanked this post: RyanD
Offline OnemindeTopic starter
« Reply #26 on: May 10, 2016, 10:20:53 am »
Not sure who you are replying to Kilrah or if it is just in general, but I'll take a shot at it.
Yes, you need to run things localy, aka have an OS. Snapdragon support both Android and Linux. Dev board can have external HDD - so, solved.
When it comes to optics, yes, this is extremely important, but its not a problem. There are plenty of suppliers for optics out there. Optics is the single most expensive part of any projectors because good glass is expensive.
If there is a will then there is a solution.
Offline RyanD
« Reply #27 on: July 28, 2016, 08:17:28 am »
I'm looking for something like this too. Is this what we are looking for? https://world.taobao.com/item/523130602739.htm#detail
Or this seems to be the one I would want: https://world.taobao.com/item/45396966558.htm?id=45396966558&scm=1007.12006.39884.i523130602739&pvid=4908172e-0f8f-4df3-b2b5-db31fbfcde12
Does this come with everything I need to run the experia display? Thanks
« Last Edit: July 28, 2016, 08:20:17 am by RyanD »
« Reply #28 on: July 28, 2016, 12:33:29 pm »
Hello.
No that's not my solution, what I went for is more or less a complete PC. Intrinsyc Open-Q 820 - allow for full Linux or Windows OS, external HDD's and much more. You can essentially use it as a media hub and 4K projector turning the project into two purposes. One DLP printer and one 4K projector / media hub. The reasons I wanted this one is so that the printer have all its hardware located on one board.
The Snapdragon 820 dev board is essentially the same hardware that is running the Sony Xperia Z5 Premium but it keeps all the input/output allowing you to use it as a normal computer.
I will however check your links.
https://www.intrinsyc.com/snapdragon-embedded-development-kits/snapdragon-820-development-kit/
Offline kony
  • Country: cz
« Reply #29 on: July 28, 2016, 04:05:45 pm »
Please do keep posting updates on this, migtht be in future crafted into something even more interesting than a projector.
« Reply #30 on: July 28, 2016, 08:08:06 pm »
If you look at the specs, its 4K@30Hz which is the whole issue with these devices. 30Hz is too low to bother. So far, the only card that will give you 60Hz is the Snapdragon 820/821. But, a custom card can be made based upon this processor, that is if anyone wants to... he he. The Open-Q 820 is more than fine for me.
Oneminde
Offline RyanD
« Reply #31 on: July 29, 2016, 01:13:07 am »
30 hz is fine for me I'm making an SLA printer. I'm just worried that I buy this board and the xperia screen but find out the connector is different and unable to figure out the solution. Do you think this thing would plug and play the xperia z5 premium screen? it says it outputs mipi dsi 8 lane does that automatically tell me it will run the xperia screen if all i know is that it seems like that screen is mipi dsi and since it's UHD it must be 8 lane?
Do you know of a better solution for running these phone screens at 30hz from displayport or other common port? I need a small UHD screen for very cheap to make my 3d printer a reality.
« Last Edit: July 29, 2016, 01:16:25 am by RyanD »
« Reply #32 on: July 29, 2016, 11:30:57 am »
The Open-Q 820 states:
- 2x MIPI-DSI 4-lane, 60fps, up to 2560×1600 (single port), 4096×2160 (dual port) - that is 8 lanes.
- 1x HDMI 2.0 up to 4096×2160, 60fps
I am no expert but the refresh rate aka Hz is in part due to HDMI version. 30Hz is HDMI 1.4 and 60Hz is HDMI 2.0 and in part how video is handled in the processor and ofc software.
You only need 30Hz for the printer, that is true, but you ask if the display is capable of running at 30Hz rather than it's native 60Hz and that I don't know. I think it would, but don't take that as a defined answer. Unless someone ells can definitely say yes it will, I think what you need to do is test it. Buy one of the boards you posted and test.
There is also this board by Hackaday that you can check out.
https://hackaday.io/project/364-mipi-dsi-display-shieldhdmi-adapter
Offline Kilrah
« Reply #33 on: July 29, 2016, 11:36:37 am »
I would not expect to be able to connect an 8-lane 60p capable display to a board that only supports 4 lanes/30p.
« Reply #34 on: July 29, 2016, 11:42:04 am »
The two boards you linked to is duel 4 lane, aka 8 lanes. Give one of them a go. In fact, I might consider one of them for the printer and the Open-Q for the media hub projector.
Offline RyanD
« Reply #35 on: July 30, 2016, 09:30:25 am »
Ok I get paid this week so I'll drop the $160 on the board and screen and well see how it goes.
« Reply #36 on: July 30, 2016, 09:37:01 am »
Kewl. Which of the boards ?
Offline Kilrah
« Reply #37 on: July 30, 2016, 09:45:52 am »
Yep, which board?
If you refer to this, which I assume given the price you quote:
From the description this does NOT come with a board, it's only a bunch of specs, documentation and development tools, the board only comes with the $750 package you also linked to.
« Last Edit: July 30, 2016, 09:48:16 am by Kilrah »
« Reply #38 on: July 30, 2016, 10:03:47 am »
Yep, which board?
Interesting, so as far as you can tell, the link forward you to the adapter board and not the processing board. Good to know.
Offline Kilrah
« Reply #39 on: July 30, 2016, 10:08:38 am »
Not even, seems there's no hardware at all with the $75 pack, only doc/software tools.
3. Evaluation Board Package Description:
In order to meet the different needs of developers, this product launch 3 different price points and different content packages:
Package A: containing only IC information and some debugging tools to assist the developer to complete the project.
Package II: contains a package of information, and includes a hardware evaluation board and evaluation board schematics, for developers and hardware verification reference.
Package III: Package A and Package II contains, and contains its driver source file, developers can make a direct secondary development.
The "Package II Click here:HDMI to MIPI_TC358870XBG virtual evaluation board _ helmet" link points to the $750 package, so the $75 is obviously the "Package A" description.
There's a link to "Package III" but it's broken.
Package II seems to have the eval board, but no display or display adapter.
« Reply #40 on: July 30, 2016, 10:18:43 am »
I C. Kinda ripping people off. Its better to get the datasheet for the Toshiba processor they are using - for free - and design a board around it. Or get the Hackaday board since its complete and support 30Hz.
Offline RyanD
« Reply #41 on: July 31, 2016, 12:04:20 am »
The hackaday board does only 1080p it can not do 4k, so there's nothing there to be had.
http://imgur.com/a/yhMGS
Designing a new board sounds fun, but I've never done anything like that before and this seems like a pretty difficult project for a first foray into board design.
« Last Edit: July 31, 2016, 12:23:21 am by RyanD »
Offline RyanD
« Reply #42 on: July 31, 2016, 12:08:18 am »
You're totally right, and at $750 it seems like a pretty bad deal, I think Oneminde's board is only $500.00. I'm still looking for a solution I mean a full on xperia z5 to drive the screen would be less. But I need to run the software on my computer and push it to the screen and I don't think the z5 phone itself wants to play nice that way.
« Last Edit: July 31, 2016, 12:12:58 am by RyanD »
« Reply #43 on: July 31, 2016, 08:50:16 am »
Correct. Both Linux and Windows have edition for Snapdragon, or ARM edition as it also is know.
If there were a simple and cheaper way to run this display, I would be all over it.
Offline RyanD
« Reply #44 on: August 01, 2016, 07:16:56 am »
These guys claim to have the datasheet, but they only use some sort of odd currency called P-coins or want minimum $800.00 to access the database of datasheets for a year. Any ideas?
« Reply #45 on: August 01, 2016, 09:36:04 am »
Yes I am aware of the situation. I have not found the data sheet either.
Offline RyanD
« Reply #46 on: August 02, 2016, 08:03:17 am »
Check your PM's
http://imgur.com/a/5UbHJ
Can I post the link to file here?
« Last Edit: August 02, 2016, 08:29:03 am by RyanD »
« Reply #47 on: August 02, 2016, 10:39:01 am »
That is up to you since its your effort. Very happy about the fact that you manage to access the PDF. Thanks buddy.
Oneminde
Offline ebclr
« Reply #48 on: August 02, 2016, 10:48:54 am »
Just 62 bucks
? 4 inches 800x480 pixel TFT color LCD with
MIPI DSI interface and capacitive touch screen
http://www.mouser.com/ProductDetail/STMicroelectronics/STM32F469I-DISCO/?qs=sGAEpiMZZMtavWIq7L07Bc86AqLmH32VNudgwLb3e3F2joTf0OIx%252bw%3d%3d
« Reply #49 on: August 02, 2016, 10:52:33 am »
Just 62 bucks
Perhaps you missed the BIG point of this thread. Its not about a random LCD screen, its about Sharps smallest 4K resolution screen, primarily for diy SLA printer, but can also be used as a projector for TV and movie.
The following users thanked this post: Kilrah
