Hi
I am working on a project where I need to make an addon-card which communicates with an other unit over a 1310nm multimode 100BASE-FX fiber connection.
The problem I have is how to interface the 100BASE-FX connections to the computers PCIe-bus..
Earlier I made a design using an Intel 82575 Ethernet controller and a ML6652 media converter chip which worked OK but the media converter chip has been EOL for a few years so I need to find a new solution.
The system would look something like this:
|CPU-<PCIe>-"CHIP1"-<MII?>-"CHIP2"|-<100BASE-FX>-|UNIT|
For "CHIP2" I have found Microchips KSZ8441 which is a PHY/MAC that supports 100BASE-FX but on the host side has a 8/16-bit MII interface. I can not find any suitable solution for "CHIP1", any one got an idea?
Regards,
Schluug
