Author Topic: 100BASE-FX to PCIe?  (Read 1887 times)
Offline SchluugTopic starter
100BASE-FX to PCIe?
« on: December 12, 2017, 02:22:23 pm »
Hi
I am working on a project where I need to make an addon-card which communicates with an other unit over a 1310nm multimode 100BASE-FX fiber connection.
The problem I have is how to interface the 100BASE-FX connections to the computers PCIe-bus..
Earlier I made a design using an Intel 82575 Ethernet controller and a ML6652 media converter chip which worked OK but the media converter chip has been EOL for a few years so I need to find a new solution.
The system would look something like this:
|CPU-<PCIe>-"CHIP1"-<MII?>-"CHIP2"|-<100BASE-FX>-|UNIT|
For "CHIP2" I have found Microchips KSZ8441 which is a PHY/MAC that supports 100BASE-FX but on the host side has a 8/16-bit MII interface. I can not find any suitable solution for "CHIP1", any one got an idea?
Regards,
Schluug
Offline drussell
  • Hardcore Geek
Re: 100BASE-FX to PCIe?
« Reply #1 on: December 12, 2017, 04:08:17 pm »
Does this computer not have a PCIe slot?  If you are you building this system from scratch, some kind of embedded thing rather than a standard PC, can't you just stick a PCIe slot on it?  Then you can just buy a standard 100BASE-FX network card.  They're readily available.
Offline Gribo
« Reply #2 on: December 12, 2017, 05:48:16 pm »
What about media converters? There are many 100Base-T to 100Base-FX converters out there.
I am available for freelance work.
« Reply #3 on: December 13, 2017, 07:27:08 am »
Sadly no, it has a completely different form factor.
So i basically need to make one of those network cards, but with a different form factor but I can not come up with a good chip solution..
« Reply #4 on: December 13, 2017, 07:29:38 am »
You mean on of these?
Any one know what circuits they use inside by chance?  ;)
Offline AndyC_772
« Reply #5 on: December 13, 2017, 07:36:47 am »
Probably just a pair of back-to-back Ethernet PHYs linked by MII.
« Reply #6 on: December 13, 2017, 08:00:24 am »
Thank you for your help!
I have also managed to find similar circuits, http://www.ti.com/lit/ds/symlink/dp83849if.pdf may work for my needs but it also "only" have a MII interface so still need to "convert" MII to PCI Express preferably. For that I need an Ethernet controller or MAC, where I have mostely found Intel parts which are not industrial temped. Hmm..
Offline AndyC_772
« Reply #7 on: December 13, 2017, 08:06:25 am »
Have you thought about using a USB to Ethernet chip instead? Microchip do them.
