Thanks yes but the light doesnt go anywhere near zero...the current does, but the light doesnt...
Yes, this is true. According to my tests, the light output drops to around 10-30% of the maximum in the valleys. Which is a lot less than incandescents at about 70-90%. So, more flicker. But not horrible, like some (improperly driven) LEDs, which not only go to 0%, but also stay there for significant portion of the cycle.
So for fluorescents the flicker index (CFD) is less than 25%...which is said to be "rarely perceptible to humans"
Which seems true as well - the incidences indeed seem "rare". As said before, I knew one guy. A few have popped up here. Not usual, but not non-existent, either. "Rarely perceptible", indeed.
What does this mean? Whenever possible, we try to build our public spaces so that you can access them with wheelchair, even though it's "rare" to be in one.
So, if you can design a light which is good for
everyone and not just "most of the people", I think you really should. You'll make a better, more universal product with good karma, not causing problems.
A good aim is to have
at least the same performance to the old fluorescents, or preferably a bit better. Add some extra margin, because it's difficult to directly compare these two technologies which will result in different "shape" of waveform.
It's worth remembering that if you don't actively keep this in mind, you can end up with
orders of magnitude worse with LEDs. And this is not OK.
OTOH, as I said in my first post to this topic, it makes no sense to aim for perfection here. Old mains-driven fluorescents were "fairly OK". Aim for a bit better (like half the "flicker index") and you'll be fine.
As a side note, when talking about "fluorescents", we mostly tend to mean the old style of direct drive from the mains through an inductor ballast. In case of electronic transformers, including CFLs, some are practically flicker-free, some flicker, depending on how much capacitance they use after rectifying the mains.
