Does it have an at least 200V MOSFET? Does it have at least 160V output capacitors? Is its voltage sensing resistor 150V+ rated?
I have wound extra turns on the coil and added a second rectifying section to get more voltage. It may say 600W, but if you read the specs further, the chance of getting 150W are dubious. What voltage are you starting from? I was slumming ebay the other day and found these. Not regulated but interesting for some applications.There are some cheap 3525 + 358 driver boards that can also get you a good start.
