Thanks. That's perfect. I wonder why the other suppliers don't carry these.
.. Carry what, pretty much the same assortment of 2.1x5.5mm plugs you linked to?
If you're looking for an in-line jack for some reason, search for 2.0x5.5mm. If you want a panel or board mounted jack,
remove the in-line mounting filter and search for 2.0x5.5 and 2.1x5.5mm. Digikey have many.
