Ponder this: The approximate dielectric breakdown voltage of air is 3,000,000 volts per metre, for PTFE it is 19.7 MV/m, polythene is similar, so is PVC. That covers most of the common insulators you're likely to find in some electronics. Given that information you don't even need to do mental guesstimation to realize that something hand held isn't going to have enough room to isolate two conductors with a 2.4MV potential difference between them, even if it was made from solid plastic with no air gaps.
Edited to add: And don't even talk about creepage distances at 2.4MV - remember, you have to hold this thing to use it.
