I started studying a project that would suit for this application .
It is an electronic load combining resistors with a MOSFET dynamic load, so that 2/3 or more of the power is dissipated in the resistors , and the load is adjustable in a continuous manner without variation of levels .
The resistors are very low cost and made of stainless steel wire (in my case , welding wire 0.8 mm in diameter - acceptable current : 5A)
For your project, load resistance should be chosen for 30A/resistor and switching would be done by automotive- relay of 30A.
The amount of relays and resistors depends on the total current value.
An Hall sensor is used for current measurement and regulation.
In parallel , there must be a MOSFET dynamic load 12V 50A 600W which will be used to fine tuning .
The assembly is cooled by forced ventilation with a fan recovered from an electric heater.
The stainless steel wire is very cheap compared to the Kanthal wire, but its resistance varies with temperature .
But that does not matter because it will be offset by fine tuning of the MOSFET dynamic load.
