Hi
From the questions and suggestions you are asking/making it sounds like this is well beyond your capabilites at the moment. I suggest you lower your ambitions and start with a lower power psu for your project.
Doing it with bought in modules will be very expensive and also very complex.
Try doing a lower power psu for micro work and tackle the high power psu later when you need it. Try a 0.1-25V 0.01-1A for the micro work.
Typically, you rely on the voltage regulation of the switcher and use a seperate current monitor circuit, when the current monitor reaches the current limit, the current limit circuit sets the voltage lower to the smps voltage control. You probably will not find this in pre built modules, you will have to design and build this.
Good luck
